Question about Kenmore 44102 Front Load Washer
Kenmore Front loader
Bearing noise, Can I replace it myself? Machine is only 2yrs old. The worst machine I have ever bought. Sears is usually great? Can you tell me how to replace?
  • Anonymous Feb 25, 2009
    I have the same problem, but what I thought was bearing problems turns out to be the rear tub assembly has broken away from the bearing rod. My machine is 5 years old. We're going to try replacing the rear tub assembly before purchasing a new machine. Have heard of many problems with front load washers...too much weight on the spindle.
  • 188 Answers
You will have to replace the rear tub assembly (contains bearing) which means practically the whole machine is taken apart. A good tech can do it in about 1.5 hours.
Two years sounds very premature for bearing failure. Make sure you are using HE (high efficiency) detergent (about 2 tablespoons for a full load).
Let me know if you want instructions on how to replace it once you get the rear tub assembly.
Posted on Feb 19, 2009
Load bearing noise when spinning.
If you have a front loader washing machine, the rear bearing can go bad a make a loud noise when spinning. The only way to fix it is to remove the basket and replace the bearing. Depending on how old the machine is + how much money to repair = new washer.
Dec 27, 2016 | Washing Machines
Replace tub bearing on top loader Kenmore elite
I have a Kenmore elite oasis top loader. The tub bearing caused the noise level to get increasingly higher over a period of a few weeks. Finally it sounded like an airplane taking off. I thought about trying to fix it myself. Meanwhile I talked to the Sears representative and they offered me a one year warranty ( my old warranty ran out last year and I did not renew). The cost was about $135.00. However, I talked to a relative who works in the factory and he thought that was a good deal. I called the repairman and am glad I did. The bearing was stuck so badly that he had to remove outer tub and finally replace with a new one. Two men came the next day and installed the new tub and associated bearing. I saved a lot of money and the washer sings quietly now. So, before you get in over your head, you might want to see if there is an available warranty. Otherwise, get ready for a fight getting the bearing out from under the washer.
Sep 26, 2014 | Kenmore 24032\24036 Top Load Washer
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
We bought a kenmore front loading heavy duty washing machine with 2-way tumble in Feb 2003. Recently two problems have become evident. First, our clothes have started to have black marks (streaks and...
Likely the cause is grease from a failing rear bearing.
Unfortunately, it's cheaper to buy a new washer than to fix this one. That's pathetic for a washer that's only 8 years old, and completely negates any environmental and economic benefits of buying a front loader.
Jan 29, 2011 | Kenmore 44102 Front Load Washer
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 44102 Front Load Washer Logo
152 people viewed this question
Sal De
fordexpert
Robert Rankin
