Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Pilot light goes out when i turn on heat. pilot light is blue flame lights good but when try to turn on heat it clicks and goes out therefor heat doesnt come on
    Scholar:
    New Friend:
  • 70 Answers
How long do you leave the pilot on before you turn on heat. The thermal pile will take 3-5 minutes to heat up before it will send a signal to gas valve. If thermal pile doesn't send signal then gas valve closes. You might need a new thermal pile.
Posted on Jan 18, 2009
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
I cant get the logs to light only the pilot light
Can you smell gas when the pilot goes out? If so, you may have too much pressure. If you just changed bottles and didn't do anything else, look at the flame sensor. It may be the problem. Good luck...Lee
Nov 12, 2009 | Blue Flame Charmglow 30K BTU Propane Vent...
My heat n glow fireplace comes on fine with all burners running but shuts off about 5 seconds later. it seems the sensor that detects a flame thinks the fire has not started and shuts down the gas. Is...
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Nov 04, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Dec 03, 2007 | Empire ECS HB06M HearthRite Heater
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
117 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
