Im trying to install tag for the first time and all i get is error 15
SOURCE: Leapfrog tag will not recognise the book Cars Tractor Tipping
Hello
Please take a look at this link and go through the steps. http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1638&p_created=1208987240
Please let me know if this helps you out.
Thank you
Testimonial: "The problem was with the country settings on the audio - it seems that the book I had was from the UK and not US. Thank you for your help."
SOURCE: How to change battery on leapfrog tag? Trying
In order to change the battery on the tag "reading pen" turn it over and there is what looks like a flat head screw head on the back of the tag, it should be white. Give that a quarter turn and the back should pop off, ours was kind of tough to get off but after the back comes off you can replace the 2 AAA batteries. I believe the "pen" has to be turned on to connect to the computer so this might fix your connection problem also.
SOURCE: The batteries in my daughters leapfrog Tag only
It might be the batteries or the brand of batteries. My son has had the tag reader for over a year now and we seldom change the batteries. Leapfrog may be against it, but we use rechargable enegerizer batteries. I can count on 1 hand how many times I've changed the batteries in the last 18 months.
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
