Question about Logitech X-240 Computer Speakers
Logitech x-240 speakers
I installed my speakers to my pc, there is no sound, subwoofer is making noise but speakers aren't any ideas as to what maybe wrong?
  • Anonymous Feb 10, 2009
    i think everything is connected correctly. it works with the ipod but not the computer.
Try to unplug everything, re-install drivers and see what happens.
Posted on Jan 18, 2009
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
I have a logitech 2.1 sound system for my laptop, as soon as I connect my subwoofer and speakers together only the speakers play and not the subwoofer. What can be the cause of this problem?
did you look at the sheet that came with them make sure that the wires go to the right spot ok then make sure that you turn on subwoofer and speakers as will jim
Nov 16, 2010 | Logitech X-240 Computer Speakers
Subwoofer sound only
Try agitating the controller (w/ the power button and volume control) and the speaker(s) that was out should immediately turned back on.
Aug 02, 2009 | Logitech X-240 Computer Speakers
Left speaker problem with X-240 Logitech Speaker / Subwoofer Sys.
pul the board out of the subwoofer box and check that the connector is soldered to the board properly if not the sound will sound scratchy.
hope thes helped
Jun 06, 2009 | Logitech X-240 Computer Speakers
I have logitech X 240 i need to hook them back to my pc, i cant figure it out, it either vibrates or a tone sound..."HELP""""
Hi. Did you plug in the subwoofer/control to the Green Slot on the back of your pc ? (should be green wire connected in the green slot)
Then you connect the 2 speakers in the back of the woofer. you will see a little slot with the label Speakers next to it.
Hope this helps, if this is not what you have already tried.
Dec 30, 2008 | Logitech X-240 Computer Speakers
Help no idea on connection hook up
The mini stereo plug goes into the green jack (three jacks in a row) on back of computer.
Speaker noise
Logitech X-240 seems love to pickup all RF noise.
Any AM [amplitude modulation] over such RF gets into audio as another noise - some might pick up AM radio signal although won't sound clear at all with some amplifiers [I am serious] - which has high gain preamps - less shielding and unmanaged ground wire handling.
Re-engineer with shilded cable - and [I don't know how normal users will do] - make sure the docking part is not the RF picker.
Well, when your CPU is processing millions of transistors are switching, and we call that digital noise, usually systems with high SNR {signal to noise ratio} should be more immune to such.
One more thing, it could be just the audio card [be it plugged in PCI bus or in Motherboard] could be a bad one - which is picking up noise - rearrange all cables inside CPU box - and check.
Isolate the problem - if it is from CPU, and audio-card --> audio line-out amp chip is picking the noise, - unplud the card or swap with another good audio card, possibly different make/model.
If the audio is on motherboard - do disable through BIOS setup.
Dec 17, 2008 | Logitech X-240 Computer Speakers
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
Logitech X-240 Computer Speakers Logo
286 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
