SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: My lg blue ray dvd player wont play regular dvd's
sounds like a bad optic or a software issue
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: I can't get my blue ray player to play Avatar Blue
Like Kelt67 said a firmware is needed....Avatar holds a lot of memory on the blu ray disc as that's one reason there are no trailers just strictly the movie and that's it on the blu ray....Avatar works perfectly fine in my PS3 but then my fiance tried watching on a regular Sony blu ray player and it just sits and loads forever....needs a firmware upgrade need to pop the firmware disc in and download by contacting your blu ray manufacture if no ethernet port on your blu ray player.
SOURCE: Will not play avatar blueray DVD
I have just had this issue, apparently the firmware needs to be updated. I am at 1.38 but there is a newer version (1.65) available. Look at the following link:
http://www.pioneer.co.uk/uk/support/software/BDP-51FD/index.html#download_18
and look at 'Download the update instructions'. This will tell you how to check your current Firmware Version and how to update it if it is required.
