Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Swingline hd shop stapler. cannor locate hd staples. # 804-809
Wide crown staples. gut is only 10 years old. need 804 now 1/4"
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
  • 299 Answers
SOURCE: I can't load staples into my Swingline electric
Try loading with fewer staples to see if that helps and make sure there are no loose staples jamming the mechanism.
Posted on Apr 28, 2010
  • 224 Answers
SOURCE: My Power Ease stapler is
Try spraying the stapler mechanism with WD40 or a good light oil.
Posted on Dec 23, 2010
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Sep 13, 2009 | Tools & Hardware - Others
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
59 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
