My Luxaire Air Conditioner show error E3 and its not working
  • 521 Answers
SOURCE: Fault E3
it indicates the problem of a compressor as the fan works fine .i feel the compressor is not able to cool the device.i will suggest you to get it checked by a proper technician.
Posted on Aug 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a wind chaser portable air conditioner
They make a few different 12,000btu models.
Click HERE for the manufacturer's web page to select and download your specific manual.
These error codes are not available in the manual.
Please contact them Monday through Friday, between 8:30 am - 4:30 pm PST,
Toll Free 1-800-405-2943 Inside the US
1-310-827-8615 Outside the US
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
  • 3 Answers
SOURCE: I have a Toyo Aircon
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Posted on Apr 18, 2010
hvac1960
  • 2133 Answers
SOURCE: I have E3 showing up
Please check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3
Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control.
Posted on Dec 10, 2010
Error 3 luxaire heatpump
It's the compressor it's not comming on check the capassator in the outside unit it's 60 far rot it popped course the motor was struggling to start if the compressor it empty it burn out the cap
Aug 26, 2016 | Heating & Cooling
I have a aircon that showing me the error code e3 on the display board. can you help me with this problem
Hi I googled (error code e3 for Sanyo 12000 Btu Mini Split Air Conditioner) and found this link below of a short youtube video of the answer you're looking for, Also on the right there are other video's you might be interested in...I hope this helps you..CHEERS..
https://www.youtube.com/watch?v=nISwqnhul90
Mar 22, 2016 | Sanyo 12000 Btu Mini Split Air Conditioner...
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
Luxaire air conditioner not blowing cold air
make sure the outdoor coil is clean and is running. if it is running you may have a small refrigerant leak and be low on charge
Aug 25, 2012 | Heating & Cooling
I have E3 showing up on my Conia air conditioner an cannot find the booklet that came with to find out how to fix it ???
E3
Dec 10, 2010 | Heating & Cooling
What is an E3 error message
E3 FROST PROBE OPEN: Normal operation is allowed. Replace probe.
E3 FROST PRObE OPEN: Normal operation is allowed. Ohm frost probe. Replace probe if ohm value not read. If ohm value is present replace board.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
495 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
