Question about M-Audio Studiophile AV 40 Monitor Studio Active
Studiophile av 40 buzzing noise
Buzzing sound
2 Suggested Answers
  • 1212 Answers
SOURCE: Studiophile Av 20 Speaker has power but no sound
Do the level controls/volume controls move freely? or with difficulty? are the jacks correct for length and polarity? Do they "pop" when input is unplugged?
Mute button somewhere?
Posted on Jan 30, 2012
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Jan 30, 2012 | M-Audio Avid Maudio 99005226600...
The left speaker of my M-Audio Studiophile AV20 smells like burning, have taken apart and no wires are disconnected, have tried to find the thermal cut out (if there is one) and cannot find any type of...
If you are smelling a burnt smell, then you have probably burnt out the speaker coil. You would need to take both speakers to a local repair centre in your area and have them checked out. They may be able to repair the speaker or may have to replace it.
Dec 14, 2017 | M-Audio Avid Maudio 99005226600...
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
I have recently purchased a set of M-Audio Studiophile BX8a Deluxe studio monitors. I can't register them for warranty because I can't find any serial number on the monitors or box that they came...
Call M-Audio and ask them about it... It is POSSIBLE that your speakers are counterfeit. It has been happening with high value audio equipment. There has been some failures of this product as well. Also contact the company you bought them from. There is a lot of grey market stuff on Ebay... I hope that wasn't your source.
May 30, 2011 | M-Audio Studiophile BX8a Deluxe active...
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
Right speaker quit working after 6 months
swop the speakers overs this will tell you weather it is the speaker or the amp. if the speaker then it has blown or the crossover unit has blown. the crossover unit splits the signal to the bass /middle and top frequencies. if you want an easy way out after you have checked the speakers/amp by swoping them just go and buy a new pair but make the sure they are the same impedance as the old pair as you can easily damage the amp
Apr 10, 2011 | M-Audio Studiophile AV 40 Monitor Studio...
Static and crackling noise from the right speaker
It could be that the input jack is or cable is damaged. The input to the right speaker is from the left speaker via speaker cable. Check that wire and try a new one. All speakers are susceptible to some type of interference. Make sure the cables aren't tangled and free from other powered equipment.
Hope this helps
Mar 30, 2011 | M-Audio Studiophile AV 40 Monitor Studio...
Studiophile AV20 left speaker doesnt work when connected. its passive, and does function when plugged to another power source. Right speaker cannot support left, or any volume above mid setting, and burns...
Probably NOT a transformer. Most likely in the power amp. Many have a thermal cutout that shuts the thing down when the chip/stick gets to hot. Your description leaves some questions... IF you don't get anything at all out of the left, then look first for a short from the amp to the output jack. This probably has a dual chip amp in it and half that chip may be bad heating up and shutting the whole thing down.
Jan 01, 2011 | M-Audio Avid Maudio 99005226600...
M-Audio Studiophile AV 40 Monitor Studio Active Logo
Top M-Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Are you a M-Audio Music Expert? Answer questions, earn points and help others
