Question about Clarion DA-1030 Humidifier
Clarion da1030 heating element doesn't work
How can I get a new element? or should I buy a new humidifier? mine is 5-6 yrs old.
    Genius:
  • 2,920 Answers
Buy a new one the cost to repair the oldone isnt worth the headache buy new
Posted on Jan 18, 2009
  • fiantella
    fiantella Feb 08, 2014
    "Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier." In other word, remove side tanks. Remove casing (tower). No need to unscrew anything, just lift it. You swill see the 3 slots underneath the restart button. Blow it with a hair dryer for 5 minutes. The green light should turn on.
Heater Element for Hunter Niteglo Humidifier is not working
Heating elements are pretty reliable. They usually have a thermal fuse or thermostat that will open before ruining the element. If your handy with a multimeter, you can check the continuity of the parts and the element itself.
Mar 04, 2014 | Hunter 35216 Warm Mist Humidifier w/ 1.2...
My sunbeam humidifier doesn't work
Do you mean Dehumidifier? A machine that takes the humidity out of the air. If this is what you mean and you hear the fan motor working with no water dripping then the problem is that the coil which holds freon gas has leaked out the gas and can be recharged again with the leak fixed of course. Depending how old the unit is you may be better off buying a new model. Repairs can be costly. Hope this helps!
Mar 26, 2012 | Humidifiers
Can't remove all that scale on this v745a humidifier. thanks
Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and let it sit for 30 minutes, Then start the humidifier and let it run until almost all of the solution has been used. Turn the unit OFF, empty the remaining solution and fill the tank with Bottles Distilled Water. Turn the unit ON and run for 30 minutes. This will flush out any of the remaining solution. The remaining water should be disposed of and in the future, use Bottled Distilled Water, rather than tap water. That way you will not have to worry about calcium and mineral build up at all. Plus, the mist that's generated will be totally void of any harmful minerals.
Hope this helped you solve the cleaning issue. Please let me know. Thanks!
Apr 19, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
It has stopped working. How do I clean it. Can the element be washed with soap?
Best way to clean it is with vinegar, it will break up the mineral deposits I'm sure the element has on it. If it is like mine the element is covered in white scale, and has stopped working. May not be worth the effort though, my element is now completely clean but the unit still auto-shuts off after about 5 min.
Mar 09, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier does nor work and no water light is on
May 20, 2010 | Clarion DA-1030 Humidifier
Clarion da1030 steamed carpet to white?
Hi, I really hate to give bad news it affects my ratings! The hot water didn't bleach the carpet, more like washed the color out. The dye in the carpet was no match for boiling hot water and the result was washed out spots. You can try to find some commercial dyes to fix the spots or replace the affected area. Sorry!
Feb 06, 2009 | Clarion DA-1030 Humidifier
How do I clean the heating coil and the humidifier?
Gently wipe, chip, and scrape as much scale as you can. If more cleaning is necessary, soak the pieces in vinegar.
Mar 12, 2008 | Clarion DA-1030 Humidifier
Built up minerals on heating element
SOLENOID DOES NOT SEEM TO BE WORKING.
If your humidifier is wired to run only wen your fan is on. if your water supply is could you will not get any humidity unless the heat in on. you need to connect the humidifier to hot water then you can keep the fan on the on positions by your thermostat and set your hemostat to 35% hum.
Jan 06, 2008 | Aprilaire 550 Humidifier
Clarion DA-1030 Humidifier Logo
120 people viewed this question
Top Clarion Humidifiers Experts
Paul Carew
Dennis
Are you a Clarion Humidifier Expert? Answer questions, earn points and help others
