Question about Panasonic SC-BT100 Theater System
When volume button is pressed it does not stop going up or down
When I press the volume button instead of advanceing one number at a time (eg 22 to 23) it continues going up or down until I hit, ok. It did this once before. I changed the batteries and it corrected the problem. However putting in new batteries has not helped this time. This system is less than 6 months old. Thank you for your help.
  • 4 more comments
  • sendtoshazam Jan 20, 2009
    Purchase date 8/17/08. Our SC-BT100 has done exactly the same thing. First time was two months ago. It corrected itself after 1/2 hour or so. Today, it lasted two hours before it went back to normal. How do you send a unit into the Warranty Service with a intermitant problem? And if we let it go, the Home Theatre Sound System could go toes up after the warranty period and we would be paying to have it repaired.
  • raysouza Jan 23, 2009
    I have the exact same problem.  The panasonic support site is useless.
  • Coros17 Feb 08, 2009
    I have had my unit for 2 months and it just started doing the same thing. If you inquired with Panasonic, have you heard back yet?
  • Anonymous Feb 25, 2009
    I had the same problem on my Panasonic SC-BT100 Theatre System which I purchased only 3 months ago.
    Whenever I adjusted the sound up or down, it would quickly increase to full volume or decrease to the lowest volume. Volume could only be contolled by adjusting the volume button on the unit itself.
    This problem happened whether I used the Panasonic TV Remote (TH-50PZ800U), SC-BT100 Remote or my Motorola PVR Remote.
    I was able to resolve the problem by unplugging the unit (SC-BT100 Home Theatre) for 5 minutes then plugged the unit back in. Powered it up using the Remote. The volume control up or down then operated normally using the Remote Control.
    Hope this helps.
  • Anonymous Mar 12, 2009
    Same as above....all of a sudden the volume kept going up or down tot he highest and lowest setting.
    Does an un-plug fix the problem? Have Panasonic said anything?
  • Anonymous May 10, 2009
    I had the same problem. A 5 minute unplug fixed the problem. I am concerned why this happened in the first place? Panasonic products have been excellent too myself in the past, I hope this unit doesnt let me down!
You can also use the cancel button on the SC-BT100 remote to keep the sound volume from accellerating up or down if you don't want to take the time to unplug for the 5 minutes, if your watching something and don't want to miss it.
Posted on May 19, 2009
I have the exact same problem after having the bt100 for 3 months. First it happened on the unit remote so I used the viera linked panasonic tv remote, then it happened there as well. Unplugging it did fix the problem for me as well, but I don't know for how long. I called Panasonic and they said they have no reports of it yet, they are looking into it and will call me back with an answer.
Posted on Mar 30, 2009
I posted a message with panasonic and have not heard from them but I was able to fix the problem by unplugging the unit then waiting a few minutes, then plugging it back in.  I got the idea from your statement about the batteries.  Hopefully panasonic will realize that there's a problem and send us a fix.
Posted on Jan 26, 2009
Why is alarm light flashing? 5800
The ink absorber is full,The waste ink error is based upon time instead of actual volume in the tank. You can reset the counter by the instructions below.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the STOP/RESET button, then press and hold the POWER button.
(3) Release the STOP/RESET button, Next press and release the STOP/RESET button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the STOP/RESET button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Dec 18, 2015 | Canon PIXMA MX310 All-In-One Printer
Toshiba 20A22 the kids took the color out of the
Don't try to reset it to factory. That will cause you more problems that will be harder to fix, especially with no remote. (Rhetorical question: Why do so very many people lose their TV remotes. How does that happen?)
Press the Volume Up and Down buttons at the same time. This will display the on screen menu. Release the buttons when the menu is displayed.
Now press the Vol Up button each time to advance the menu until the word 'PICTURE' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
Now press the Vol Up button each time to advance the menu until the word 'COLOR' is displayed. Press the 'CHANNEL down / ENTER' button to select this part of the menu.
To add color back, use the 'VOLUME up / Set+' key. To reduce the color, press the 'VOLUME down / Set-' key.
The user manual doesn't give a way to exit the menu, so my guess is that when left alone the TV will exit out of the menus itself on a timer. If not, try pressing Volume Up and Down together once more.
Sep 12, 2014 | Televison & Video
Set time on MSP74810W
Instructions for setting an MSP74810W watch.
Press the "Mode." button three times (the "Mode" button is the one next to the lower left of the dial when facing it).The first time you press you'll see the ST, or stop watch function, the second time you'll see the AL, or alarm function, the third time you'll be back to the time of day function but the seconds will be flashing.
Change the flashing seconds digits to read 00 by pressing the "Start" button (the "Start" is the button next to the upper right of the dial when facing it).
-To advance from the flashing seconds' reading to the hour of the day's digit/digits you press the "Reset" button at the lower right of the dial,
-To advance from the flashing hour digit/digits to the minutes digit/digits you again press the "Reset" button,
-To advance from the flashing minutes digit/digits to the month's digit/digits you again press the "Reset" button,
-To advance from the flashing month's digit/digits
to the day of the month's digit/digits you press "Reset,"
To advance from the flashing day of the month's digit/digits to the day of the week's abbreviation you again press "Reset,"
-To advance from the flashing name of the week's abbreviation back to the seconds' of the minute you again press "Reset," and from there you can go through the cycle again.
While the hour of the day with its A[M] or P[M] designation, the minutes of the hour, the month of the year's number, the day of the month's number, or the abbreviation of the day of the week's name is flashing press the "Start" button once, repeatedly, or hold it down to advance the number or letters to their correct designations.
Once all designations are correct push "Mode" so that none of the numbers or letters are flashing. Your watch is now set.
Apr 01, 2014 | Watches
Remote pauses and flashes before i can press any other button quick enough
open the remote control and clean very well the keypads from dust, corrosion, etc. Resolder any colder joint from the board. Clean the contacts batteries very well.
May 30, 2013 | Televison & Video
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
Want all region code for Sony theatre player DAV-X1G
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
May 13, 2011 | Audio Players & Recorders
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
Bluetooth NS-BTHDST won't turn on
1- Plug the charger into a power outlet and connect the headset
2- Press the Volume Up and Volume Down buttons at the same time for resetting the device.
To Insignia: Please provide a line covering/linking this problem in Troubleshooting section of the manual, too. I found it in the Resetting section on page 22.
Mar 03, 2009 | Insignia Bluetooth Wireless Headphones...
Error 22
dear gine
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Remote volume
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4330
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
You may want to set up the "push through / punch through" this allows you to change the tv volume while still in the satellite mode, this should be in the manual.
Many thanks
Mark
(www.sparky-uk.com)
Jan 05, 2008 | One For All URC4220 Remote Control
Panasonic SC-BT100 Theater System Logo
652 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
