Question about Camping, Backpacking & Hiking
Want to replace a VECTOR 1378 Meridian battery
VEC 1378 MERIDIAN BATTERY NEEDS TO BE REPLACED
SOURCE: Vector Super Sport Spot VEC127Y replacement battery
I need a new power supply for my Vector Spotlight, Model VEC127Y. Any suggestions as to where one can be purchased?
John seadoc@aol.com
Posted on Nov 17, 2008
SOURCE: i have a vector vec 156 that i can not get the
The rubber cover will have to coxed off. There is a slight lip that it sits in at the back. I ran a screw driver under it around the back of it to get it dislodged and then worked it forward.
Posted on Mar 02, 2010
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
  • 283 Answers
SOURCE: looking for replacement parts for vector spot light
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
Posted on Jul 29, 2010
CarlGlas
  • 283 Answers
SOURCE: My Vector model #VEC117FS has a battery that is
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Posted on Nov 13, 2010
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
No work is done by gravity on a bowling ball that is rolled along a bowling alley because why?
If the bowling alley is perfectly horizontal, the center of gravity of the ball will remain at the same height measured in a fixed system of reference. As you know the gravity force is directed vertically downward. To calculate the elementary work of that force you evaluate the inner product dW= vec(g).differential of vec(5). However since the displacement vector vec(r) remains in a horizontal plane ( Prependicular to the direction of vec(g), and the ball does not bounce and leave the horizontal plane) the angle between vec(g) and vec(r) is equal to 90 degrees. the inner (scalar product is =0).
A simpler way to remember it is that the work is equal to g*(difference in height)
Jan 07, 2012 | iPhone Apps
My digital screen reads:service 4wd switch
  • The 4 wheel drive switch tells the VEC- Vehicle Information Center - weather you are in 4 high or 4 low.
  • It's on top of the transfer case between drivers side from and rear doors.
  • The VEC has been know to cause this problem to so if the switch does not fix it then the VEC might have a loose wire or be malfunctioning. The VEC plagued the Grand Cherokees for a few years.
  • This is a dealer part.
  • Also check the transfer case fluid level while there. Pull the top plug and fill it until the fluid just barely seeps out.
Regards, Tony
May 25, 2011 | 1996 Jeep Grand Cherokee
Meridian gold gps will not turn on
Try to connect your gps device to a computer to see if it will charge or turn on. Then you try to use your battery on another gps to see if it will come on,if it comes on, then it means the battery is okay, but if it does not turn on, then it means the battery is bad and need to be replaced. Try to use another battery in your gps to see if it will come on. If it works, then that settles it, but if it does not, then it means there is an internal problem with the unit.
Jan 01, 2011 | Magellan Meridian Gold GPS Receiver
I have not been able to find a store who handles the vec 142 in our area I have questions like battery battery life and how much are replacement batteries if available what is life of bulbs and how are...
Nov 01, 2010 | Vector VEC 142 Rechargeable High Intensity...
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
My magellan meridian gold does not turn on ,,and if it does the screen is all blue
The unit is coming on but the LCD display has Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} separated and needs replaced.
Apr 23, 2009 | Magellan Meridian Gold GPS Receiver
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Camping, Backpacking & Hiking Logo
362 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
