Question about Clarion DRX4575
How do I set the clock
I disconnected the battery in order to repair the alternator in the car. On reconnecting the battery the clock on the radio started displaying the wrong time. I don't know how to reset the clock. I would like to be instructed.
  • Louis Ross Jun 24, 2007
    Thanks KaeZoo. I give you a 10 out of 10.
    Jamoon.
  • Anonymous Apr 17, 2008
    I need to know how to reset my clock on my Clarion DRX4575
  • 156 Answers
1. While pressing the BND button, press the DISP button to display the clock display. 2. While pressing the BND button, press and hold the DISP button for two seconds or longer. 3. Press the Left button, then set the current hour. 4. Press the Right button, then set the current minute. 5. Press the BND button, then the clock is set. You can download a user's manual from this link: http://www.clarion.com/us/en/MungoBlobs/615/523/DRX5575(Manual).pdf
Posted on Jun 24, 2007
SOURCE:
Remove starter acura 2000
  1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
  2. Disconnect the battery negative terminal first, then the positive terminal
  3. NOTE: The PCM memory setting is needed after reconnecting the battery.
  4. Raise the coolant reservoir, then remove the battery and battery base.
  5. Remove the alternator belt and alternator.
  6. Remove the left exhaust manifold cover.
  7. Remove the left damper fork.
  8. Disconnect the left suspension lower arm ball joint.
  9. Remove the left driveshaft.
  10. Remove the transmission stop collar, then remove the exhaust pipe A.
  11. Remove the front mount mounting bolts.
  12. Attach the chain hoist to the engine
    1. Remove the left engine mount bracket
    2. Disconnect the starter cable and BLK/WHT wire, then remove the starter.
    3. Install in the reverse order of removal.
  13. NOTE: When installing the starter cable, make sure that the crimped side of the ring terminal is facing out.
    1. Enter the anti-theft code for the radio, then enter the customer's radio station preset.
Nov 29, 2016 | Acura Cars & Trucks
W58814 RADIO
a quick tip for you. disconnect the battery negative terminal just before 12:00 O'clock noon. Then right at noon reconnect the cable. Most radio's default set to 12:00 noon. Now you clock is set.
Mar 11, 2014 | 2001 Toyota Prius
I can change the time on radio clock but it just stays on that time
I had this problem after a main dealer repair that required the battery to be disconnected for a couple of hours. I put i right by leaving the battery disconnected for 12 hours until all the memory including radio presets had cleared. After reconnecting it returned to normal. I t may take yours longer or less time but the radio presets clearing seems to indicate it will restore the clock.
Oct 24, 2013 | 2007 Toyota Aygo 1.0
Bmw 735 li e65 change battery and i get many problem no value to set clock radio not working cd also i disconnect the battery still the same problem
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your BMW service centre and get them to enter this code for you.
Jan 15, 2013 | Cars & Trucks
How do I fix alternator on Honda civic 2005?
Instructions
Make sure you have the radio unlock code for your Civic, if equipped with the anti-theft radio. Disconnect your negative battery cable and gather the tools required for the procedure. Make sure your workplace is safe and well-lit.
Remove the drive belt to better access the alternator. Remove the 4P connector from the alternator, and then remove the battery wiring module.
Use your socket wrench to remove the alternator bolts, and then slip the alternator away from its mount.
Mount the new alternator in its place. Use the torque wrench to tighten the bolts to 33 ft.-lbs. This is the specific rating for the Honda Civic, do not disregard this. Not properly tightening the bolts could cause problems.
Attach the 4P connection and the battery wiring module. Replace the drive belt and reconnect the negative battery cable.
Make sure your radio and air conditioning are turned off, and then crank the engine. Rev the engine to 3,000 RPM with the vehicle in park. Hold it in this position under you hear the radiator fan turn on.
Take your foot off the accelerator and let the engine idle for five minutes. Set your clock and use your code to unlock your radio.
Jul 24, 2012 | Cars & Trucks
Exactly what is the procedure to efficiently replace the Audi S4 alternator
Audi S4 V8 engine 4,2 liters alternator:
1. You need radio code
2. Disconnect car battery
3. Release tensioning roller
4. Remove ribbed v-belt
5. Detach electrical connexions from the alternator
6. Remove fastening alternator screws
7. Pull out the alternator
8. Install new alternator on the bracket
9. Refit all in reverse order
10. After battery connection you must set up radio code
11. Check up electrical supply from the alternator with a multimeter in parallel connected on battery: around 14 Volts tension voltage value, engine at idle runing.
Dec 29, 2009 | 2001 Audi S4
My CD is stuck and reading no disc how do I get it out without damanaging my system?
Turn the radio off and then disconnect the battery, wait 2 min then reconnect the battery. Turn on the radio and hit eject, that should reset the radio and you have to set the stations and clock. Note: radio must be off before disconnecting the battery, os your going to have to re-enter the radio code to have the radio active again.
Good luck and keep me posted.
Jul 22, 2009 | 2008 Chevrolet Malibu Classic
The cd won't eject out the stereo.
Turn off the radio and disconnect the battery for 30 seconds. Make sure the radio is off before you disconnect the battery. once the battery is reconnected, turn on the radio and eject the CD and reprogram the stations and clock. Good luck and hope this helps.
Jun 27, 2009 | 2002 Mercury Mountaineer
How can i reset my check engine light?
disconnect the battery for 5 minutes.
Jun 09, 2009 | 1998 Pontiac Grand Prix
Location of start motor
Looks like it is on Passenger side @ Junction where transmissiom& Engine meet
2001 Acura 3.5RL V6-3474cc 3.5L
  2. Disconnect the battery negative terminal first, then the positive terminal. NOTE: The PCM memory setting is needed after reconnecting the battery.
    1. Raise the coolant reservoir, then remove the battery and battery base.
    2. Remove the alternator belt and alternator.
    3. Remove the left exhaust manifold cover.
    4. Remove the left damper fork.
    5. Disconnect the left suspension lower arm ball joint.
    6. Remove the left driveshaft.
      1. Remove the transmission stop collar, then remove the exhaust pipe A.
      2. Remove the front mount mounting bolts.
      3. Attach the chain hoist to the engine
      4. Remove the left engine mount bracket
      5. Disconnect the starter cable and BLK/WHT wire, then remove the starter
      6. Install in the reverse order of removal. NOTE: When installing the starter cable, make sure that the crimped side of the ring terminal is facing out.
      7. Enter the anti-theft code for the radio, then enter the customer's radio station presets
Mar 04, 2009 | 2001 Acura 3.5RL
Car Audio & Video Logo
287 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
