Question about Hardware & Accessories
I want light to stay on from dusk to dawn,I followed directions and light goes out at eight minutes.
Model 0072836
  • 6 Answers
SOURCE: I installed a dusk-till-dawn switch on a light.
Make sure the sensor's eye is pointing North
Posted on Dec 07, 2009
SOURCE: dusk to dawn light flickers on and off
I answer questions for free here at fixya.
I know timers and electrical devices.
If the following information does not help, add a comment and I will work on the problem further.
You posted under the Intermatic ST01C timer.
I assume this is not a new installation, so we know the wiring is correct, and your programming worked correctly in the past.
You have the timer set up for dusk to dawn.
The manual has troubleshoot section.
http://waterheatertimer.org/Intermatic-st01c.pdf
I have read the manual and tested&wired the timer and programmed the timer.
A low battery can cause this kind of problem, even if BATT is not flashing on screen.
The manual also says when encountering a problem, you can reset and then reprogram the timer.
The manuals says to check for loose wires, and defective bulb.
The timer does not work on circuits longer than 100'
The timer does not work if there are underground wires.
The symptoms you describe sound like loose wires or a light bulb.
I would check the wire nuts at the timer and at the outdoor fixture.
Change the outdoor bulbs.
As last resort, reprogram the timer.
These electronic devices go bad, and the ST01C has a 1 year warranty >>> combine the short warranty with the long troubleshooting section, I believe the product fails frequently.
Posted on Nov 03, 2010
SOURCE: i am trying to wire a utilitech 70 watt hps dusk
Lumark makes a 70 watt HPS sold at Lowes
If this is your product:
Add a comment and tell me what color wires are on the back of the HPS, and what color wires you have, and what type of fixture you are replacing.
I will probably be able to help.
Posted on Nov 07, 2010
SOURCE: I have a Woods Outdoor
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Posted on Dec 16, 2010
Testimonial: "Thank you so much for your feedback to my question. I will try your suggestions. If they fail, I will buy the type of timer you recommend! :)"
SOURCE: i am programming my sto1 and I cannot get to dusk
ST01C instructions are confusing, and are longer than space allowed for free answer.
Open following link for re-written instructions that might be clearer, with illustrations how the display should look.
http://waterheatertimer.org/ST01C-program.html#astro
To clear the timer, hold down on-off button and press reset button.
Release reset button and keep holding down on-off until INIT displays.
If you go through re-written instructions and get confused, add a comment with exact step where it is confusing and I'll pull out the ST01C I use for testing and maybe I can find what is causing the problem.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 03, 2011
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector winchestercollector.org/models/model-1894 ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    I got a win model 70 308 serial number 862911
    You don't say, but I presume you want the date of manufacture?
    http://oldguns.net/sn_php/winmods.htm
    Other info for you.
    1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
    2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
    3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
    4. Related searches for win model 70 308 serials
    5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
    6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
    7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
    8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
    9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
    10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
    11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
    12. Pagination
    May 24, 2016 | Optics
    Looking for what year my Winchester model 94 was manufactured in. The serial number is 2374881
    Here you go. These sites will help you.
    • 108 POSTS
    2012-08-04 · Serial Number info for Winchester Model 94 User Name: ... Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 ...
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, ... Our database contains values of serial numbers through 5103248 which ended the year ...
  • Model 1894 (Mod 94) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 1894 (Mod 94): ... Please enter a serial number and click the submit button. ...
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm Winchester Model 94 Serial Numbers. In 1894 Production began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or less, ...
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification ... The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • winchester 1894 serial number decoder ' Jeremy blog fitubangscam.blog.com/2013/05/04/winchester-1894-serial-number-decoder Ladder sight CARBINE Winchester 1873 1892. Winchester Model 1894 - Wikipedia, the. Winchester 1894 Serial Number ' Gun. Winchester Model 94, winchester model 94 ...
  • Winchester Dates of Manufacture - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... (Mod 94) Model 1895 Model ... Model 59 Shotgun ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms How can you find the age of a Winchester Model 94? ... What is the age and value of a Winchester Model 94 serial number 3910875?
  • How do you find out if a Winchester Model 94 is pre-64 ... https://answers.yahoo.com/question/index?qid=20081128210042AA3vaql
    • RESOLVED
    • 14 POSTS
    • 13 TOTAL ANSWERS
    2008-11-28 · Best Answer: The serial number is the best bet 95s had grip safeties as late as my 1982 model Put the serial number in here and it will give you ...
  • Dates ' Winchester Collector winchestercollector.org/dates Serial Number. Get Manufacturing Date . Manufactured Date. ... History of Winchester; Winchester Model Information; When Was Your Winchester Made? Winchester ...
  • http://www.bing.com/images/search?q=winchester+model+94+serial+number+decoder&FORM=HDRSC2
    May 22, 2016 | Optics
    Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
    Hello Mark
    my connection here doesn't permit weapons searches, but all the info is below.
    Serial Number info for Winchester Model 94 - The Firing Line Forums
    https://thefiringline.com/forums/showthread.php?t=322230 Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden ... a rusted $50 tomato stake Standard Carbine, or a $10-20,000 Special Order ...
    Winchester Model 94 32 Winchester Special. ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-94-32-winchester-special.-... My question is why is there so much variance from site to site on this model gun. I have one with a serial number 115,814. According to most sites that serial ...
    Winchester Rifles Modern Lever Model 94 Pre 64 For Sale ...
    www.gunsamerica.com/Search.htm?C=767 108 Listings - This is a pre-64 model, serial number 14375xx, and features a straight grip .... Winchester Model 94 Top-Eject Lever Action Carbine .32 Win Special ...
    Winchester Model 94 - Gun Collections Online
    guncollectionsonline.com/winchestermodel94.htm Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .22 magnum, .38 Special/.357 Magnum, .44 Special/.44 Magnum, .45 Colt (or .45 Long Colt), ...
    www.savage99.com/winchester1894_dates.htm Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
    Winchester Model 94 (.32 Winchester Special) - YouTube
    2q==? 7:01 https://www.youtube.com/watch?v=fNRDe5H--S0 Nov 24, 2013 - Uploaded by 88zukcrawler Short video of my favorite gun....the Winchester 1894 (94). Mine is a post 64 model (1972 year by the serial ...
    winchestercollector.org/models/model-1894/ .32-40 - introduced in 1894 ... .32 Winchester Special - introduced in 1901 ... As serial numbers approached the one-million mark, the official model designation ...
    Winchester Serial Numbers - ProofHouse.com
    www.proofhouse.com/win/index.html Model 1885 Single Shot · Model 1886 · Model 1892 · Model 1894 (Mod 94) · Model 1895 · Model 53 · Model 55 · Model 64 · Model 65 · Model 71 · Model 88
    Feb 29, 2016 | Optics
    Winchester model 74 serial # 11901, what year was that gun made
    My Internet at work doesn't like 'weapons'. These links will help you find the date.
    Model 74 - Winchester Dates of Manufacture
    oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
    oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
    Winchester Model 74 .22 sr dating question ' The Firearms Forum
    www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
    Winchester Model 74 Value And Date ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
    Jan 22, 2016 | Winchester Optics
    I need a users manual
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    Jan 09, 2016 | Cell Phones
    Instructions for 2006Painted Imaganirum Table Table
    A.T., VIN model "C" (4x2), TH400, 6 cyl
    A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-305 (5.0L)
    }A}}400}466495" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-350 (5.7L)
    }A}}400}466496" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-379 (6.2L, diesel)
    E>}B}}400}466497" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH700, diesel
    A.T., VIN model "K" (4x4), TH400, 6 cyl
    B@}}}400}466499" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH400, 8 cyl, diesel
    A.T., VIN model "K" (4x4), TH400, 8 cyl, gasoline
    A.T., VIN model "K" (4x4), TH700, diesel
    FFC}B}}400}466502" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "C"
    FFC}A}}400}466503" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "R"
    ECB}B}}400}466504" type="radio" name="userInterchange" />M.T., 4 spd, 4x4, (VIN model "K")
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    A.T., VIN model "C" (4x2), TH700, gasoline
    F=A}B}}400}466508" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH700, gasoline
    }B}}400}466509" type="radio" name="userInterchange" />A.T., VIN model "R" (4x2)
    Oct 20, 2012 | Cars & Trucks
    What year/model transmissions will fit a 1989 GMC sierra, 2500, 350 engine, 2-wheel drive? Thanks
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    Jan 14, 2011 | 1989 GMC Sierra
    Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
    1935 KIRBY Model R*
    19?? KIRBY Model 2R
    19?? KIRBY Model 3R
    19?? KIRBY Model 4R
    19?? KIRBY Model C
    1939 KIRBY Model 2C
    19?? KIRBY Model 3C
    19?? KIRBY Model 4C
    Model 505 - 1945
    Model 508 - 1948
    Model 509 - 1949
    Model 510 - 1950
    Model 511 - 1951
    Model 512 - 1952
    Model 513 - 1953
    Model 514 - 1954
    Model 515 - 1955
    Model 516 - 1956
    Model 517 - 1957
    Model 518 - 1958
    Model 519 – 1959
    Model 560 - 1960
    Model 561 - 1961
    Model 562 - 1962
    1963/64 Sanitronic VII (Sirocco)
    1965-67 Dual Sanitronic 50 (Sirocco)
    1967-70 Dual Sanitronic 80 (Avocado green)
    1970-73 Classic 1CR (Medium brown, gold bag)
    1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
    1976-79 Classic III 2CB (Candy-apple red, plaid bag)
    1979-81 Tradition (Dark blue; intro of paper bag)
    1981-84 Heritage (Gray/orange)
    1984-89 Heritage II Legend (Charcoal/gray/red)
    1989-90 Legend II (Dark rose-pink)
    1990-93 Generation 3 (Alabaster)
    1993-96 Generation 4 (Medium gray)
    1996-99 Generation 5 (Maroon)
    1999-01 Generation 6 (Black/Yellow)
    2002-05 Kirby Ultimate G
    2005-06 Kirby Ultimate G Diamond
    http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
    Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
    Hardware & Accessories Logo
    271 people viewed this question
    Top Hardware & Accessories Experts
    Gene Haynes
    Hippy_dd
    Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
