Question about Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television
Power green lite wont stay on but 4-5 seconds
I had a friend bring by a Daewoo 47" projecion TV whic he said had a severe 'trapezoidal' problem (screen width OK at top & ottom but about 2-3 inches narrower in middle... By the time unit had ben loaded in pickup, driven 3 miles over here & unloaded, after they left I connected cable and A/V inputs, fired it up and that problem was gone! (maybe bad connection/cold solder joint,etc that fixed itself with the move). anyway I did use front panel menu to set convergence, sharpness & conrast to get a really good picture outta it. I ran it for 8 hrs x 2 days in a row for burn in and it still looked fine... Finally, just before calling him to come get it back (at no charge since I only spent an hour on it) I decided to finish up by doing a regular PM (preventative maint) and opened the back lower cabinet, carefully vac'ed out the dust/dirt on circuit boards/components/wires, etc and (here was probably my mistake)then CAREFULLY disconnected 1 at a time then reconnected each of the inter-board wiring connectors We live in FL and so the high humidity, salt & sand can cause corrosion at the connection point and my hope was that this action would 'clean-up' any bad areas and make the connections solid (low inpedence) for longer than not doing it... Next time I turned it on (and ever since!) I get red standby LED, then when push small power button I get green (on) LED and can hear relay click and the beginning ov the high voltage to the guns coming up BUT it goes back to red (standby) in 3-4 secs no matter which other buttons are pressed (Cable, Menu, Volume, etc while its green Anybody worked on 1 of these or seen anything like it? I cant find anyone locally who is willing to service these and really hate to send it back to frien in WORSE shap than when I got it to try to fix a different problem (kinda ruins your rep as a good electrical engineer!) Also tho I have downloaded both user and service manuals I lost my Tektronics 475 scope a few years back and havent needed it often enought to worry bout getting any kind of replacement osciloscope... Can any one help?? thanx! --George-- BSEE Ga Tech 1978 [email protected]
Update: Talked with customer services and was that after a TV is discontinued, They no longer make parts for it. So the only inventory is what was in stock at that time. Asked about maybe some sort of a discount on buying a new TV from them, No luck. So so far it looks like any one with this problem is just out of luck. I will be writing the Better Business Bureau to report this. I thought a company had to stock repair parts for seven years after line was discontinued. Maybe a class action suit is in order if enough people have this same problem. If anyone has heard any different please let people know. I for one will never buy or recomend this company for anything after this expensive lesson .
Posted on Nov 29, 2008
Have same problem. This is an e-mail sent to Daewoo. We purchased a DSJ-4710CRA/5510CRA TV about two years ago from BJ'S wholesale club. TV has been fine until about a month ago. Turned TV on and it shut down after a minute.Called local TV repair people and they came out . First call they suspected the High Voltage generator. That trip was $102.55.They ordered the part from Daewoo. Part came in and was installed. TV still did not work. That call was $115.56. They took unit to their shop for further testing. Found the Deflection board was bad. Call Daewoo to order and was told part is not available. Tried a board rebuilder and no luck. This TV was built in 2004 and purchased in 2006. How am I to justify any more purchases from Daewoo that can't be repaired after two years of use. I work for a large copier manufacturer that if you purchased a copier that had to be replaced after two years I would probably never see you as a cutomer again. I'm attaching the service tickets for credibility. I would appreciate any help with this matter. Will follow up if I hear anything about this problem.
Posted on Nov 09, 2008
    New Friend:
There is a relay on the circuit board that the power cord connects remove the screw that holds the board to the wooden case,slide out the board carefully moving black and blue wires so you can see the front of board (side with all the heat sinks on it). the relay is black with blue writing, it clicks when you push the power button the black plastic is a cover this needs to be removed with the TV unplugged,once the cover has been removed plug the tv back in.!!!!!!!!!!!!!!!!!! if you do not think you can handle this dont do it!!!!!!!!!!!!!!!!! take a pencil with an eraser tip push the power button,you can see the relay working but when it clicks back the tv turns back off, push the power button again, push the pencil eraser down onto the shiny metal top part hold it in until the tv comes on, if this does not work unplug the TV and rapidly push the shiny metal top part in and out these moving parts get dirty and manually pushing them usually fixes it plug the tv back in push power,push down with eraser and hold after the tv comes on it should stay on when you remove the eraser. if the tv stays on turn the power on and off a bunch of times, put the tv back together and you saved your self some cash, the way tv repair shops fix this problem is replace the whole board !!!!!!!expensive!!!!!! good luck!
Posted on Apr 02, 2011
  • Bobo8504 Jan 02, 2012
    I tried this and mine is still doing the same thing. Any more suggestions?
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Hi, my Daewoo Plasma 42"
If the power light stays green then the current absorbed by the different boards appear to be normal. If that is the case then most likely you have a bad contact in the data cables or in the mainboard.
You will need to open the tv, inspect for damage and reseat all the components then (if that doesn't fixes it, you will need to extract the mainboard and check the soldering on the board and the status of the processor.
Jul 24, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
Tv power on and sutdown after a series of bips the green light change to red and stay red
Tv power on and sutdown after a series of bips Problem with the Daewoo DSJ-6000LN 60 in. Rear Projection Television tv power on and sutdown after a series of bips the green light change to red and stay red
Jun 15, 2010 | Daewoo DSJ-6000LN 60" Rear Projection...
Sony bravia KDF-E50A12U rear projecion tv wont turn on
Hi it sounds like it could be an issue with board that powers the lamp ,it's called the ballast.When you put a new lamp in the ballast has to provide more power ,when it starts to go weak it will not light up.Sometimes you can put your old lamp in and will work fine.Try partstore.com they might have it right there.Hvae a blessed one!
Mar 02, 2010 | Televison & Video
Tv clicks on and off. timmer light stays lite.
This could be a number of things, but first step might be: check that the power button on the TV is not stuck on, there could be a faulty push button or the button is stuck.
Aug 19, 2009 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on. green lite for 4 secs, 3 times, then off. D52W20
It could be several issues from a bag power supply, the TV is connected to a power strip with several other components hooked up (DVD, Sound System, Xbox, etc.).
Try connecting to the wall directly and see if it now starts up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Daewoo DSJ-4710CRA 47" Rear Projection HDTV-Ready Television Logo
567 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
