Question about Acer Aspire L100 PC Desktop
Acer aspire l100 service manual - Acer Aspire L100 PC Desktop
SOURCE: Acer aspire l100
This is THE single most common problem with the Acer Aspire L100. Initially really happy with it, but then after five months, mine started freezing and then refusing to boot. Since then it's been very tetchy so I just bought a new computer. The problem lies in the design, it's TOO small to allow adequate ventilation to all the components - something Acer should have figured out before selling the machine. If you can boot your machine up to bios, go into it and change the temperature settings so it runs the fan at full blast. This may help, but I cant garantee it, sorry! If your warranty is valid, demand a refund.
Posted on Jul 09, 2008
SOURCE: Over Heating Problem In Acer Aspire L100
There are two solutions to this problem. First set the fan in the PC Bios to rub at full speed all the time. This was too noisy for me.
Second, If you are running Windows Vista, you can adjust the Maximum Porcessor Utilization. From the Windows Control Panel select the Power Options icon. Then select "Change plan settings" for which ever power plan the PC is set to use. Then select "Change advanced power settings". Expand the "Processor power managment" by clicking on the "+" symbol. Finally click on the "+" for "Maximum processor state". I would try changing this setting to "90 %". This worked fine on my ACER L100 and it no longer overheats.
Posted on Aug 16, 2008
bibleman01
  • 334 Answers
SOURCE: Acer Aspire L100 PC Desktop
Get an external network modem that uses usb port that's my advice because sometimes we can search forever lookinf when we can enjoy it already.
God Bless Greg
Posted on Nov 17, 2008
knotbeerdan
  • 413 Answers
SOURCE: Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: L100 overheating
Replace the thermal grease. It only costs about 10 bucks. The thermal grease they use in these systems is cheap stuff. After I replaced it my system is quiet, no loud fan noises and my system can actually stream videos now!
Posted on Apr 20, 2009
Why does Acer l100 PC shut down?
You need to service you pc ar laptop. The cpu needs to get new thermal compound every 3 to 6 month's add me on facebook Nic fourie for complete guide to how the service your own pc or laptop
May 11, 2014 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hi i want VGA drivers
    VGA drivers differ from system to system. Try the following links to get the VGA driver that will be suitable for your unit.
    - http://support.amd.com/us/gpudownload/Pages/index.aspx
    - http://www.brothersoft.com/downloads/vga-driver.html
    - http://download.cnet.com/VGA-Driver-Ati-8-33-zip/3000-18492_4-197341.html
    hope these links have been helpful?
    Jul 20, 2010 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    I have a Acer Aspire L100 and would like to restore to factory settings please help
    If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
    http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
    Apr 11, 2010 | Acer Aspire L100 PC Desktop
    Where is the power on button on the acer l100
    moz-screenshot.jpgdear,
    if you have manual see in it on page 27/51 and if you dont have then here is the manual for you, see this page and u will see that the power button is on the front side at a corner...
    http://safemanuals.com/user-guide-instructions-owner-manual/ACER/ASPIRE-L100-_E
    click on pdf file named "Download the complet user guide" and after click that there a new small window will open and ask you to type code that is being displayed on the left side one by one...
    goodluck...
    surely, it will fix your issue so dont forget to rate it...
    Aug 31, 2009 | Acer Aspire L100 PC Desktop
    How do you turn it on?
    On page 14 of the user's manual, they show a close-up of the location of the power button on your Acer L100 Desktop PC.
    If you're missing your user's manual, Here's a link to the PDF version from their website (for the PDF, check page 24): http://www.acerpanam.com/synapse/data/7117/documents/AcerSFF.pdf
    I've also uploaded it to the Manuals section of the Aspire L100 series section of this website.
    Hope this helps,
    -Nick F.
    Mar 09, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    130 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
