Question about Toshiba MK6476GSX 640 GB SATA II Hard Drive
My Toshiba Hard drive dosen't work usb driver not found or can't find an update MK6476GSX
It won't update when uninstall it dosent work properly
5 Suggested Answers
SOURCE: USB Hard Drive Problems
Let me try
Posted on Sep 27, 2008
bronk50
  • 27725 Answers
SOURCE: My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Posted on Sep 18, 2011
bronk50
  • 27725 Answers
SOURCE: need driver for toshiba 3.0 usb portable hard drive
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope it helps
Posted on Jul 01, 2012
falachen121
  • 55 Answers
SOURCE: My Toshiba 500GB hard drive
try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files. download it from
http://www.softpedia.com/progDownload/Asoftech-Data-Recovery-Download-179432.html
Posted on Dec 13, 2012
How to fix hard drive error message ata device
I think you are talking about Toshiba MK6476GSX, if yes then this might help you
http://forums.toshiba.com/t5/Satellite-Laptops-all-other/Win7-Dectecting-Hard-Disk-Problem-with-TOSHIBA-MK505GSX-ATA/td-p/189018
Jul 20, 2014 | Toshiba Computers & Internet
I have a HP Pavilion dv6-6c35dx pc and it will not recognize my sata disk device.
If the BIOS is not accepting any info about the drive being connected, then nothing else will. It could be that controller just does not work. On a board that old, it is probably not a worthwhile effort to try a hardware fix.
Using an external enclosure for the drive is probably the best bet.
Jun 05, 2017 | Toshiba MK6476GSX 640 GB SATA II Hard...
How to fix a toshiba a105-s4001 when it won't boot up from hard drive or dvd drive
You can install Win7 from an USB drive.
follow this link to find more about it and for step by step instructions.
http://forums.mydigitallife.info/threads/7850-Installing-Windows-7-From-USB-Drive-3-Steps-Easy-Process
Another option is to go for external optical drive.
Good luck...
Feb 06, 2012 | Toshiba Computers & Internet
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
Hi! I've got a Toshiba Satellite L300 and it won't boot anymore. I get past the initial toshiba-screen where I can press F2 and F12 but afterwards there's just a black screen with a little...
You can retrieve your data by removing the hard drive and connecting it to an USB hard drive adapter then plug it into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files to back up your data.
You can then return the hard drive back into the Toshiba then format the hard drive and reinstall Windows to get your Toshiba working again.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
I can not open my usb flash drive
Try it on a different computer; it may be your USBconnection. You could try to uninstall it or update the drivers by clickingSTART, CONTROL PANEL, SYSTEM, HARDWARE, DEVICE MANAGER, and USB controllers atthe bottom of the list. Try updating the drivers first by RIGHT CLICKING andchoosing update. If all that doesn't work try RIGHT CLICK and uninstall them.The new found hardware will reinstall them automatically, if not right away itwill the next time you boot up the computer.
Jun 03, 2011 | Computers & Internet
I plug my hard drive into the computer and u can see the safely remove hardware sign at the bottom right of the computer but it doesn't show up on My computer and when i open other programs while the hard...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
if you can see your usb drive but its not working
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 16, 2011 | Toshiba Canvio 500 GB USB 2.0 Basics...
USB disk not found!/ USB drive write protected, when formatting USB drive
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Nov 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a Toshiba L355-S7812 laptop. I've recently replaced the hard drive and re-installed the OS. The driver for this CD/DVD drive won't install. The Device Manager indicates the driver is missing or...
HI
Have you uninstalled it in device manager if not uninstall it restart the laptop and hopefully windows will install it correctly when it re-installs it and if it dosent
follow this link and type in your make model and os hopefully you will find the driver
good luck
Nov 18, 2010 | Computers & Internet
Unable to install IOMEGA HDD on Vista Home Premium
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
Oct 18, 2007 | Iomega 32883 40 GB Hard Drive
Toshiba MK6476GSX 640 GB SATA II Hard Drive Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
