Question about Jl Audio E4300 Car Audio Amplifier
Wire e4300 to subwoofer
Wire diagram for running subs on e4300
3 Suggested Answers
SOURCE: How should I wire my 3 subs to the 500/1 amp???????
* Pioneer TS Series 12" Subwoofer
* Power Handling:
o 400 Watts RMS
o 1200 Watts Peak
* Impedance: 4 ohms
* IMPP with Aramid Fiber Cone
* Dual Mass Magnet with Magnet Cover
* Dual 2-ohm Voice Coil
* Aramid fiber IMPP composite cone
* Spring-Compression Binding Posts
* 3-layer fiber woven radial surround
* Aluminum voice coil bobbin
* Integrated single-sided terminals
* Frequency REsponse: 18 Hz - 500 Hz
* Sensitivity: 89 dB
Posted on Mar 29, 2008
  • 55 Answers
SOURCE: wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Posted on Aug 14, 2009
Wiring/sub-woofer not putting out!!
The remote wire from your head unit should be blue and there should be a wire that connects that to your amp. Make sure it is hooked up. Also, if you are using the high in put wiring up above, it shouldn't be mixed with your RCA. That wiring diagram is not needed for the subs. You should also check the gauge on you power wire that runs from the battery to the amp. If it is 4 or less it should be good if it is Copper Clad aluminum (CCA) it will put out power similar to 8 gauge copper wire. Most of the time the problem with the low output of subs is the amp wiring kit. You could have great subs and a great amp, but if the wire isn't any good it can sound like ****. Just FYI in case you weren't familiar with any of that. Always try to get pure copper wire when it comes to the power cable. You can google information about it. If you're wiring there is fine. Again, check the remote wires. Also check to see you have your amp levels turned up as well. As for the violet and violet/white. Those are referring to you speakers in your vehicle. Not your subs.
Oct 02, 2012 | Car Audio & Video
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
How to wire post to post for 1subwoofer audiobahn aw1200n
depends on how you're hooking them up to the amp, and what type of amp it is you are using. but to wire them parallel, and drop the ohm rating, assuming it's a dual voice coil sub, you wire - to + on the sub, then - to the - on the amp, and + to + on the amp. Here's a diagram:ae0c628.jpg
Oct 07, 2009 | AudioBahn AW1200 Car Subwoofer
How do i wire two kicker l7 dual 2 ohm subs to play on a mtx 7801 class d amplifier
Hello moore_broder,
Your MTX 7801 is stable at 1 ohm, but you cannot wire a pair of DVC 2 ohm subs to that impedance. They can only be wired to 1/2 ohm which is too low or to 2 ohms.
Series the voice coils and parallel the subs. On each sub, jumper Black to Red/White Dot, then run both red's (positive) and both black/white dot's (negative) to your amp terminals.
The diagram is here.
Hope this helps.
Sep 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Apr 25, 2009 | Car Audio & Video
Need wireing diagram for hooking up two as12sq 12-inch square 2
you can run each sub at either 4ohms or 1ohm which means that two of them will run at either 2ohms or .5ohms....be careful how you wire them because most amps cannot handle .5ohms very well and might blow.....to wire them for 2ohms you will need to wire each sub the following way. they have two voice coils make a jumper wire connecting the negative on one coil to the positive on the other coil. what you are left with is a coil with an open positive and the other coil has an open negative. when both subs are wired like this connect the two positive terminals together (1 from each sub) and the two negative terminals together (1 from each sub) now the subs should be wired together at a 2ohm load. run the two positive wires into another combined wire which will run to the positive speaker terminal on the amp. do the same for the negatives
Apr 17, 2009 | Hifonics AS12SQ Car Speaker
12 inch insignia subwoofers model # ns-sub12
how to wire 12 inch insignia sub woofers
Apr 01, 2008 | Car Audio & Video
Subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Nov 19, 2007 | Car Audio & Video
Wiring diagram
The LEd wires need a wire run from the speaker to the Fuse block in your car. The small Red wire from the LED will be the one that hooks to Swtiched 12 Volts supply on the fuse block so that your Led Turns on when you turn the keyswitch on. The Black wire goes to ground, or to a metal part of your cars body, probably the same point where your Amp is Grounded.
The Octane R10 is a Single Voice Coil or SVC.
AMP+ to Sub+
Amp- to Sub -
Use 12 guage wire.
Nov 07, 2007 | Phoenix Gold Octane-R 10/10d Car Subwoofer
Jl Audio E4300 Car Audio Amplifier Logo
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
