Question about Brother PT-65 Personal P-Touch Electronic Labeling System Printer
Brother P-touch 65 - display writes "error" - Brother PT-65 Personal P-Touch Electronic Labeling System Printer
Use a power supplier with more mA capability.
Posted on Jan 22, 2009
On the p touch PT-65 is there a way to get an underscore _ ?
The link to the manual for Brother PT-65 is below. You will find the underscore symbol by pressing the "sym button". Further instructions are on page 4 under heading "add a symbol" if required.
Nov 02, 2017 | The Office Equipment & Supplies
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
How can i get a p65 instruction manual
Hi halliemain,
Here's the download website for the user guide for Brother BRTPT65 P-Touch.
Click on the link for the download: BRTPT65 P-touch
Hope this helps!
Good Luck!
Thank you for using Fixya!
Mar 11, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Drum error wont go away
This should be an easy one. Your Brother doesn't know it has a new drum until you tell it like this:
  1. Open the front, where the drum is.
  2. Touch the CLEAR button.
  3. The display will ask if you replaced the drum. I believe you touch 1 for "yes."
  4. Close the front door.
Nov 10, 2010 | Brother MFC-9840CDW Laser Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
The printer can be stuck in double line mode, although it indicates that it is single line mode. Switch between the two modes, pressing " enter" and " clear ", until you are in single line mode again. Now you can change text size again.
Jun 03, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT-65 Personal P-Touch Electronic Labeling System Printer Logo
118 people viewed this question
James Cagle
James Cagle
Jim Keysor
