Sony vaio PCG 7171L no boot
No bios screen no boot, just battery and power on lights
Dr Geek MD
  • 201 Answers
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Posted on Feb 22, 2009
  • 97 Answers
SOURCE: Sony VAIO PCG-8X2L will not boot. it loads the
You have a currupt bios firmware. You need to pull out your battery, and disconnect the Cmos battery. Next leave it for at least 24 hr. to make certain you clear Cmos. Now get the latest bios update and have it ready to install. Make certain your a/c power supply is attached during this process. Put in a bootable cd with the firmware on it and see if it loads the new Bios firmware. You can then try to boot the Laptop or PC. I have had good luck doing it this way on most laptop's. Good Luck Phil
I have seen some cases where it is a motherboard problem, but not very often. I have also seen where it is caused by defective memory. You may want to test your memory in another laptop or borrow a chip to see what happens.
P.S. Here is the link to your bios firmware.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGTR3AP1
Posted on Dec 10, 2009
  • 7 Answers
SOURCE: VAIO PCG-8Y2L won't boot - no display, no nothing....
I smell a Hardware fault,or your Display might be busted...I suggest you Visit a PC store and let them check it out.
Posted on Dec 24, 2009
Geekman
  • 32281 Answers
SOURCE: sony vaio pcg-7a2l boots only to a black screen
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Mar 15, 2010
mariolands
  • 2296 Answers
SOURCE: sony vaio pcg-272l all in one with catv connection
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 25, 2010
I have a sony vaio model pcg-7171l and i have replaced the motherboard, hard drive and battery. i cannot get it to install windows properly, i have tried multiple times....the last time it ran somewh
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 23, 2013 | Sony VAIO Computers & Internet
Sony vaio a417m wont boot
If you only want to enter BIOS then you can try the below keys .
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Aug 06, 2012 | Sony VAIO Notebook
Sony vaio pcg-272l all in one with catv connection bios screen password can't get pass it is there a soloution
Dec 22, 2010 | Sony VAIO PCG-K33P Notebook
Oct 30, 2009 | Sony VAIO Notebook
I have a Sony PCG-5G3L when I go to boot it up,
I have the same problem some times. Just reboot and it should work :)
Jun 27, 2009 | Sony VAIO (PCWA-A200)
Sony pcg k45
Put the cd in and restart. If it doesn't give you a message to press "x" to boot from cd, then you need to chage the boot order in the BIOS.
To get into the BIOS, restart and press del or F2 (it might say something on the screen like press del to enter setup) that is the BIOS.
Change the boot order to CD first.
Dec 18, 2008 | Sony VAIO K45 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
