Question about KitchenAid Microwave Ovens
How do I replace the door spring on my kbhc109 built in mircrowave oven
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
espressonist
  • 1711 Answers
SOURCE: The door spring is broken
which is your brand and model
Posted on Aug 06, 2011
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
Jan 25, 2015 | KitchenAid Microwave Ovens
KBHC109 magnetron needs replacing
So what is your question... do you need a meg tube, need to know how to replace, you need some one to replace.
Mar 27, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid Microwave Ovens
Built in Microwave won't turn off!
Your machine is probably burned up by now ... but I will try to help you.
I suspect your door safety interlock switches are selded in the closed position. Remove the cover and look on the right hand side for these small switches. Unplug the device and be mindful there is 25,000 or more volts waiting to get you in the silver thing to the back side. Check the switches with a ohm meter. There is a common terminal, a normally open terminal and a normally closed terminal. My guess is one or both switches are going to read closed (short)
Sep 07, 2009 | Sharp R-1480 Microwave Oven
Mar 26, 2009 | KitchenAid Microwave Ovens
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
