Question about Durabrand DU1901 TV
Hissing Sound When I turn on the TV I hear a hissing sound which subsides after about 30 minutes. How can I get rid of that Sound?
  • 398 Answers
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Posted on Jun 28, 2007
Maks a hissing sound when i first crankit. inside on passanger side i hear a hissing sound about every 30 secounds. the air on passanger side is cold and hot. and hot
check for a vacuum leak on the hose going to the actuator for the heater door. Sounds like the hissing sound may be a vacuum line. Hope this helps.
Jul 09, 2014 | 2003 Chevrolet Silverado 1500
Hissing and jumping while driving
Check brake power booster they have a check valve that when faulty they sound like air escaping
Apr 23, 2013 | Dodge Stratus Cars & Trucks
Air noise coming from under bonnet audi a8 d2
Sound is completely normal on all Audi's.
Your A8 uses an Orifice tube to regulate the pressure between the two halves of your air conditioning system. A hissing sound is normal after a shut down as the system equalises. Usually lasts about a minute and is more noticeable on warmer days.
Location on an A8 is on the very right hand side of the bonnet just under the windscreen - that's where the hissing will be coming from.
Apr 17, 2013 | Cars & Trucks
I CAN HEAR A HISSING SOUND BY THE FUEL CAP AFTER I TURN OFF MY TRUCK
If you hear a hissing sound from the gas cap then the o ring that seals the tank is either cracked or tore. the tank has to build up pressure. thats where u r hearing the hissing sound replace it, it should stop after.
May 23, 2009 | 1996 Chevrolet C1500
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Hissing sound inside my sansui tv
You have a short on the secondary side of the transformer that is hissing. You are going to need someone knowledgeable in electronics, to help you find the short. Most likely it is your Horizontal output transistor.
Sep 08, 2008 | Sansui Televison & Video
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Sony KV-20FS120
It's normal for new sets, especially Sonys to do that due to some sort of gas build-up in the new tube. My set still gets a high-pitched buzz after power on and lasts for a minute or two before silencing. If the hissing continues when the TV is turned off return it to the shop ASAP. It could be a problem with the power supply, something getting ready to blow up. Good luck
May 30, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
216 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
