Question about MSI K9MM-V Motherboard
Video card to slow for windows 7
When running virtual dj the music cracks if I have the window open if I drop the screen the music play without cracking. I need the window opening for mixing. need help.
  • MSI Master
  • 3,606 Answers
Hello here is the homepage:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver&os=All
Maybe you need more ram, your system supports:
Supports Dual DDR2 533/667/800
2 DDR2 DIMMs (240pin / 1.8V)
Supports a maximum memory size up to 2GB.
Try also to upgrade the graphic driver.
virtual dj takes a lot of power, from the pc:
http://www.virtualdj.com/products/virtualdj/index.html
Depending the size of the cpu.
I think you have to buy a pc, a little faster than you have now.
Good luck
Posted on Jan 23, 2013
2 Suggested Answers
  • 11800 Answers
SOURCE: no boot. see initial msi display but nwindows 7 operating system
The corruption in Windows is too extensive to be fixed by a simple Repair. You will have to do a proper reinstall (with full format). Once that is done test the hard disk for errors, it might be dying.
Posted on May 31, 2010
Running windows 7 home on one PC and windows 10 on another. I don't have the installation disc anymore, and the drivers I downloaded from Dell don't seem to work.
Daisy Mae,
The Pocket DJ is not compatible with Windows 7 or Windows 10. If you plugged it into your computer and it did not recognize the device or show up in "My Computer' then it will not work. You would need a windows 7 and Windows 10 drivers.None are available..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 01, 2016 | Dell Pocket DJ MP3 Player
The "galaxy of games card classics"will not run/play on my dell 1750 inspiron for some un known reason, can you fix this problem? '
You can run older programs in Windows 7. Here are 2 fixes:
1. Run a Program in Compatibility Mode in Windows 7. This one is easier, so try this one first. It should work.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
2. Run Windows XP Mode with Virtual PC. This one more complicated because it involves installs and running a virtual system. Use only if you feel comfortable with instructions.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Sep 25, 2012 | Dell Inspiron 1750 Notebook
No sound from internal speaker, but I can hear using headset. The problem heppened with Laptop HP 620.
This is a possible damage on the internal speakers or a connection fault at the headphone jack connector. you might need to open the laptop to check and confirm on the connectors.
Jul 25, 2011 | HP Computers & Internet
I have the cd rom disc stratego and I am trying to install it on windows 7 and it will install but it will not let me play it.. is there somewhere where I can buy the cdrom for windows 7 or somehow that I...
This game won't work on Windows 7 in any of the compatability modes. The only way to get this game to work is to run it in windows xp. The good news is that you can get free software from Oracle called virtualbox. Using virtualbox if you have a xp installation disk, you can create a virtual windows xp that runs within your windows 7. Stratego plays fine from within a virtual windows xp, provided that you play from the cd-disk not the virtual hard drive. Install the game normally in the virtual windows xp environment. After installation, to play the game, you must be in virtual windows xp, then double click the CD/DVD drive icon that looks like a bomb. If you try playing from any of the shortcut Stratego (also looks like bombs) launchers or the stratego.exe file installed on your virtual hard drive, the game will not work.Just go to My Computer in the virtual windows xp, and double click the cd/dvd bomb icon, and the game starts up fine.
Feb 18, 2011 | Infogrames Stratego for Windows
Virtual vinyl 6 64 bit driver
i have virtual vinyl and have the interface box , it will not read on a 64 bit laptop on windows 7 , do i need to buy the dj /io box for it to work ?
Sep 24, 2009 | Numark DJ/iO Sound Card
When i open virtual dj it says.., warning the skin you are using has a higher resolution.... i have changed the screen resolution and tried various different things.... i have scoured the internet to try...
there is no problem in it you can just ignore it... if u want to remove that use cracks for that soft... and make your system main pc resolution more...
Jul 30, 2009 | Computers & Internet
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
I just installed rainbowsix/vegas2 the gameis installed the music plays but the game screen remains blank an the music keeps playing my computer is running windows vista.
you need to to check the display settings and the system requirement before installing and running the game
System Requirements
Windows XP/Vista
3GHz Processor (3.5GHz recommended)
1GB RAM
7GB Hard Disk Space
4x speed DVD-ROM Drive
128MB DirectX 9.0c compatible, Shader 3.0 enabled Video Card (256MB DirectX 9.0c compatible Video Card recommended)
Latest DirectX 9.0c compatible Sound Card
DirectX 9.0c (you may need to download the latest drivers for your video and sound card)
Keyboard, mouse / X-box 360 Controller for Windows
Online multiplayer: broadband Connection with 128Kbps or faster.
*Supported Chipsets: ATI Radeon X1600-X1950/HD 2000 series / HD 3000 series / NVIDIA GeForce 6600/6800/7/8 series.
Laptop models of these cards are not supported but may work.
These are the only ones that will run this game. Additional chipsets may be supported. For an up-to-date list please visit http://support.ubi.com.
System Configuration may require minor adjustments to the configuration of your operating system and/or updates to hardware component drivers
Notice: This game contains technology to prevent copying that may conflict with some disk and virtual drives.
May 23, 2008 | Computers & Internet
Computer won't open DJ Ditty
Windows Media Player 11 not compatible with this player.
The device doesn't know if it is a MTP or MSC device - in one of these modes, it will not allow access to the music folder. unfortunately, there is no way to switch between these two modes in the menu settings. Go to Control Panel - Device Manager - find MTP Deivce and update driver.
Sep 28, 2007 | Dell DJ Ditty MP3 Player
MSI K9MM-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
