Question about PfaFF Sewing Machines
Foot control for hobbylock 4760
Foot control delivers very little power to machine even when pressed down completely.
  • 323 Answers
SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
Posted on Sep 27, 2008
ohms
  • 1879 Answers
SOURCE: presser foot lever
Try turning it off and disconnect the foot pedal (depends on the model).
Worst, the power surge damaged the sewing machines small computer and it will require service.
Posted on Nov 24, 2008
  • 69 Answers
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Posted on Feb 09, 2009
  • 1116 Answers
SOURCE: I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Posted on Mar 07, 2010
  • 22 Answers
SOURCE: Bernina 900 ''Electronic Power'' foot control needs repair
You will need to go a bernina dealer to by those pins the part number is 325 355 031 and each pin cost around $4.00 each
Posted on May 03, 2010
Machine going too fast
The foot pedal is faulty, the electronic voltage control is not working and only when the contacts are connected physically does the machine receive any power (maximum) It depends on your type of foot pedal whether or not it is repairable
Feb 17, 2014 | Toyota Sewing Machines
How do I do a rolled hem on aPfaff hobbylock 4760 overlocking machine
you might try youtube and see if they have a video
or try this link for a manual,they have a downloadable or hardcopy
http://www.sewingpartsonline.com/instruction-manual-pfaff-4760.aspx
Mar 07, 2013 | Sewing Machines
Looking for a rolled hem foot for a Hobbylock 786, lost mine?
check with these sites about the part you need--you'll have to email them about the foot
sewvacdoctor.com
a1sewingmachines.com
Sep 09, 2012 | Sewing Machines
I have a pfaff hobbylock 796.
Has any little kids been around lately? Have they had access to your sewing area and machine? (thinking perhaps the pressure foot tension has been tightened down) If it has been tightened, losen it a couple turns, see if that helps (remember, left to loosen, right to tighten)
When is the last time you oiled this machine? Typically sergers require a clean and oil each time you go to use them. Locate the bar that correlates to the presser foot add a drop of oil to the bar and let it seep in. After a few minutes try lifting the presser foot.
Also does the presser foot lever move at all?
Aug 20, 2012 | PfaFF Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
When pressing the foot control the machine won't run, it shows the presser foot blinking on the screen even when the presser foot lever is down.
check the connections, if they are good, your foot pedal has a short in it, so its not completing the circuit when depressed
Jul 15, 2011 | Husqvarna Rose
HELP PLS. pfaff serger, hobbylock 788. it has been working fine. today i cant turn it on at all. what could be the problem?
Is one of the front covers open slightly? these will both have safety cutouts on them.
If not that, then could be foot control and cord that has a fault. Are you getting power to the light on it? Can you hear the engine humming? If there is nothing, then start by testing the foot control and cord.
You can probably buy a replacement foot control on one of the sewing part sights such as www.sewusa.com or www.sewingpartsonline.com
Jun 17, 2011 | Sewing Machines
Lost the foot pedal and cord to my Hobbylock serger 796 made for Pfaff. where can I purchase another one?\r\n Thanks, Charlotte
Here's a link to the Google froogle search results, they are a little pricey though... You might find a cheaper one in your area by calling around and asking for a used one.
http://www.google.com/products?q=796+foot+control+pfaff&hl=en&aq=f
-Chirs
Jun 13, 2010 | PfaFF Hobby 4260
The foot control is not working
well particular on electrical problem foot control is a switch of motor that deliver speed varies on how you press the foot pedal it consist of circular thick plate carbon the old model and the new one electronically control of power ic,It depend on how this pedal was contro.Anyway besure the power is off or unplug the machine; this control was been connected in series connection to the motor which you can test if your foot pedal control is defective. Disconnect the line wire holding foot pedal from the terminal inside motor assembly.If your not qualified electrician don.t do this.Connect the two terminal wire that inside the machine where the motor mounted.This connection is supplying your motor in full speed,Declucth your machine from the handwheel so that the motor run only.Plug the machine and switcn but you must jug only if the motor run in couple second of course without the foot control this was disconnected already.So your foot control is defective vice versa if motor does not run without foot control motor is busted.
how to fix if foot contol is defective, in carbon type you must replcace the circular thick carbon.On Electronic control check the IC if this open or some capacitor and resistor are open,Replaced any pars that had been short circuited.If the motor is defective replaced the carbon brush mounted at two side of motor case,There is an opening port.The carbon brush has spring holding push this carbon brush to the brush armature of rotor.
Mar 06, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
