Question about Canon Document Scanners and Cameras 5005B002 imageFORMULA DR-C125 -
Canon dr-c125 "unknown error" launching scan first
New scanner Canon DR-c125.. Downloaded installation software Mac OS X 10.8 (mountain lion). Turn on power, launch capture on touch and "unknown error" results. No scan. No nothing. Canon tech had me delete and reinstall software- same error. Waiting 3 days for an "engineer" to respond to tech support and give me a fix. Any ideas
mohanchennai
  • 490 Answers
SOURCE: Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Posted on Feb 21, 2008
SOURCE: Canon Unknown Error
Please run Scandisk on your computer. If the problem persists even after this, reinstall OS. You need to reinstall other applications also.
S. Mohan
Posted on Mar 09, 2008
  • 75 Answers
SOURCE: Canon 2050P ##323 Error
that is a heater error. the fuser asm. that melts your toner on to your paper. it is not coming up to temp. in time.
sorry to say the only way is to replase it. if you go on the internet googal canon 2050p fuser you can order one
C.W.H.
Posted on Jan 23, 2009
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
mohanchennai
  • 490 Answers
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Posted on Mar 28, 2009
Set up disk for canon DR 9080 path through scanner
Hi Joseph, you should be able to find the driver for your OS on the Canon website here. imageFORMULA DR 9080C Color Production Scanner
Apr 10, 2014 | Canon DR-9080C Path-Through Scanner
Canon mf 4018
Hello - Canon does not provide a Mac driver that supports scanning, BUT if you have:
An Intel Mac
and
OS 10.5 (Leopard) or later (including snow leopard, lion, mountain lion and even mavericks)
there IS a fix: Just download the free Vuescan software for Mac, then use it to scan with the MF4018.
Go to: http://www.hamrick.com
Download Vuescan for Mac OS X
Install it, and start the application. It will recognize any scanners attached.
NOTE: If Vuescan asks you to identify your printer, you will not see the MF4018 listed. Choose the MF4010 instead - the 4010 and the 4018 use the same drivers.
Oct 29, 2013 | Computers & Internet
Canon DR-1210C scanner does not work with Capture Perfect software
you can download and Install Twain driver for this model and you can scan from Any Image Editor like photoshop and Acrobat PDF editor
download link http://www3.canon-asia.com/downloads/drivers/dr/DR1210C/DR-1210C%20Driver1.1.zip
Feb 06, 2013 | Canon Office Equipment & Supplies
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
Mar 19, 2009 | Canon DR-5010C Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Canon Unknown Error
S. Mohan
Feb 07, 2008 | Canon DR-2580C Path-Through Scanner
Canon Document Scanners and Cameras 5005B002 imageFORMULA DR-C125 - Logo
356 people viewed this question
old marine
old marine
