Question about Hitachi 53FDX20B 53" Rear Projection Television
Green alignment I was watching tv and all at once the green was slopping down from the upper right to left and it has green shadows behind the upper half of the image.I tryed the magic focus and the red and blue looked fine,but the green squares were not in the correct spots on the screen and it displayed the number 3 at the end of magic focus. Thanks
  • 398 Answers
One of your convergence output IC's has burned out and needs to be replaced.
Posted on Jun 26, 2007
SOURCE:
2003 Saturn Ion and the steering wheel has some slop in it how do I fix it or what could be wrong
The steering gear box has an adjustment screw on the top cover. Loosen the lock nut and turn the screw clockwise until the slop is reduced. Jack the front end up so both wheels turn freely. Push the wheel right and left while watching the suspension components. If they move up and down. The control arm and ball joints need replacing. Have it done at a good shop that does alignments.
Nov 29, 2016 | 2003 Saturn ION
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. ...
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Red a green shadows on most objects!
use manual convergence to re align the colors. the owners manual tells you how to do this. No manual go to samsung. com in the FAQ section
Oct 11, 2008 | Samsung HCL4715W 47" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
Hitachi 53FDX20B 53" Rear Projection Television Logo
169 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
