Question about Dell Inspiron B130 Notebook
Charger sister broke my charger and i got a new one it still wont charge i think the problem is with the port where the charger goes into the mother board how do i fix that
    Scholar:
  • 170 Answers
If the port is suffering from a bad connection, you have to re solder it to the motherboard. I recomend you take it to a shop unless your an expirenced computer tech. Or you could replace the motherboard, but if your gonna do that, you are better off buying a new computer. I hope this helps. Good luck.
Posted on Jan 18, 2009
My Samsung 11 wont charge I replaced the battery but it started to hold a charges but it wont now
check to make sure the port isn't loose or damaged. the soldering might have broke from the board
Nov 28, 2014 | Samsung Cell Phones
Wont charge ive tried multiple chargers.
if its the Optimus L9, this is a simple fix. you can order a charging port for your phone. order the charging port, then google Optimus L9 repair charger, or screen, they will show you how to properly open the phone. change it, and you are good to go. (if it still doesnt work, you have a faulty mother board.)
Jan 07, 2014 | LG Optimus Black Smartphone
My bb curve wont charge ive tryed a new battery and charger the red light doesnt even turn on idk wat to do i just woke up and it was off plzzz help
Hi
Try cleaning your phone charger port wit brush.do it gently.
check for the charger port is loose with the board or not.
if its loose .you have to take it to the technician to fix it.
If this problem occured while your phone is being connected with charger then this might be a problem with the mother board.some times it happen becz of voltage fluctuation.
Thank you.
Sep 15, 2011 | Cell Phones
I have had my samsung propel for 3 years now and every time i put it on the charger i have to position the phone just right or my phone wont charge. at first i thought it was the charger but i plugged in...
Sounds like you have a cracked PC board at the charging port. Most likely caused by attempting to remove the adapter without depressing the tabs. This is an easy fix if you can find a shop to do it; keep in mind that repairing maybe as much or more then the phone is worth.
My suggestion is to position the charger so that the battery continue to charge, then replace the handset when it no longer accepts a charge. This could take a week or a year or two before the charging circuit is no longer working.
Jan 11, 2011 | Samsung Propel A767 Cell Phone
Hi, I have an Acer Aspire 5600 which has problems charging. I have recently replaced the power cord as the other one had broken. the charging pin that goes into the computer only works when facing a...
This is a common complaint of the wire shorting inside, please go to my tips page so that this particular complaint was reviewed with some tips.
The short within the wire cuts off the adaptor votlage as it is in protect mode-- not a failure of the adaptor. so have the wire **** off and connected or use a new pin at the end.
Oct 30, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
I have a laptop from Canada and was using it in Sweden where the voltage is different (i think its 230v in sweden and 110 in canada). My charger from canada broke and I tried one here which resulted in...
If the a new charge will not charge the battery, It would probably be the mother board that needs to be replaced, and its one of the most expensive parts on a laptop.
Aug 04, 2009 | Computers & Internet
My Gz One Boulder's charger port broke off. I
The same thing happened to my Gz One Boulder. I sent it back to Verizon for replacement. The 2nd Gz One Boulder also had problems with the charging port within 2 weeks after I got it so I sent it back too.
I am now on my 3rd Gz One Boulder. I've only had it 2 days. Time will tell if the charging port on this one will hold up. Frankly I doubt it.
My best advise to you is get a different phone if you have the opportunity to do so.
Jul 27, 2009 | Casio G''zOne Type S Cellular Phone
Lg rumor charging port wires broke off from port to phone
Ok same think happened to me and i found a temp solution this really works :D http://www.youtube.com/watch?v=9pYcgmLhUcQ
Jan 02, 2009 | LG RUMOR Cellular Phone
Charger port on phone busted
I don't know what you want to hear. If the USB port is broken off, you will either have to get a new phone, or open it up and solder it back on. There are probably 4 "feet" at the corners of the USB port that broke lose from the board and you will need to reattach these. Alternatively, you could find the same phone on eBay that has a broken screen or some other problem that leads you to believe it has a good ESN and a good motherboard. Buy that phone and swap the entire board out. RadioShack has a good tool kit that works with most mobile phones, it's about $15.
Jun 13, 2008 | Motorola Mobility V325 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Dell Inspiron B130 Notebook Logo
83 people viewed this question
Alun Cox
