Dimplex cheriton fire noisy fan
Cht20
3 Suggested Answers
aviral_srms
  • 1216 Answers
SOURCE: how to repair noisy fan
Try cool it down, and give it a break (if you have used it constantly over a long time). Otherwise you could try clean it for dust, some heaters sucks alot if dust into themselves.
Last option is to get to the customer support at the store you bought it at, and tell them you're problem, they will help you gladly, and probably give you a new one if they can't fix it ;)
This generally requires greasing into the motor or bearing replacement which definitely requires a service.
Posted on Nov 27, 2010
  • 4736 Answers
SOURCE: Need to replace noisy fan
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Posted on Jan 31, 2011
Testimonial: "Thanks appreciate the help. Not sure where to get replacement parts looks like a OEM motor needed. "
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
Dimplex heater model no -CHT20 will not heat up but power getting to switches
did you try it on a different wall socket.Chk the power supply fuse
Aug 09, 2008 | Heating & Cooling
Does anyone know where I can buy a small black rubber grommet for rotisserie bar on Dimplex Cheriton fire
Yes this is a fairly common rubber grommet usually available at Maplin. They are most used for protecting cables or other things from abrasion from flexing at the entry points into boxes casings or conduits etc.
Search 'pvc grommet' on google
Feb 11, 2014 | Heating & Cooling
Dimplex cheriton fire model CHT20LE wont turn on
Check the fuse isn't blown in the plug. If it is not, then you would unfortunately need to open up the fire and check the internal wiring and connections, check the switches with a multimeter to make sure they are working. There really isn't much inside these units to go wrong! So any fault should be rather easy to find
Aug 02, 2013 | Dimplex Heating & Cooling
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Changing bulb in dimplex cht20 fire
Yes this is very easy on the cheriton range of fires.... remove the coal, then remove two screws from the front of the coal holder... the whole brass coal holder will pull away from the machine. The bulbs (two of them) are located directly behind this, just behind the rotisserie flame effect. The flame effect can be pulled out of its holder to access the bulbs.
Feb 19, 2012 | Heating & Cooling
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The motor driving the flame effect has become noisy. what can i do
try cleaning the fan and then putting some oil on it might help
Jan 02, 2010 | Dimplex Compact Electric Flame Stove...
Noisy optiflame motor on dimplex cheriton fire
If you are referring to the motor of the flame effect, these are called synchronous motors (commonly used in microwave turntables. Any syncronous motor should do as a replacement, but check whether you need a 12v model or a 240v model. This information should be found on the label on the back of the old motor.
Nov 30, 2009 | Dryers
Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Apr 02, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
