Question about Maytag MGC5430 Gas Cooktop
Maytag MGC5430 Gas Cooktop ignitors spark but gas for burner comes on only after 10-12 trys
fridgetech
  • 473 Answers
SOURCE: Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Posted on Oct 17, 2007
  • 161 Answers
SOURCE: (2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
Posted on Jul 01, 2008
  • 222 Answers
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Posted on Jul 04, 2009
  • 222 Answers
SOURCE: Igniters on my Maytag gas cooktop do not spark
u nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
  • 53 Answers
SOURCE: Maytag MGC5430 cook top range IGNITION KEEPS
This sounds like a burner switch.There is one under every knob there are two wires going into them. i think the part number is 7403P367-60.
Posted on Jun 22, 2010
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
I have a cookto maytag mgc5430 and the ignition clicking wont shut off i have to unplug stove for it to stop
Hi zwerling,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 07, 2011 | Maytag MGC5430 Gas Cooktop
Maytag MGC5430 cook top range IGNITION KEEPS TICKING & SPARKING WHILE GAS IS OFF
Jun 22, 2010 | Maytag MGC5430 Gas Cooktop
MODEL MGC543OBDS GAS STOVE THE ELECTRONIC STARTERS ALL FIRE WHEN TRYING TURN JUST ONE ON..
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 29, 2010 | Maytag MGC5430 Gas Cooktop
Maytag gas cook top. One burner will not spark. other three are fine. What need to be checked or replaced? I am pretty handy but know nothing about these cook tops. Your input please.
Took entire cook top apart, dried each of the components then reassembled. I donot recomment this unless you are very handy. Not an easy job but doable. Also
try to dry it out with a hair dryer on low.
Nov 26, 2009 | Maytag MGC5430 Gas Cooktop
I have a 5 burner gas cooktop that is chrome Problem the chrome is scrached and I want to replace it
Your Maytag authorized dealer can help. Otherwise take the top to a chrome plating service.
Oct 29, 2009 | Maytag MGC5430 Gas Cooktop
Maytag stove top gas ignitor keeps clicking
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Maytag MGC5430 Gas Cooktop Logo
22 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
