Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Fan Runs all the time
The fan on my Hitachi runs continuously, even when the set has been off for hours. Any Ideas on how to proceed?
    Novelist:
  • 192 Answers
The fans run for an additional minute or two after the set is turned off. If the fan runs longer than that, then, either the 12 volt relay is stuck or the transistor that controls that relay is shorted. To find a local authorized servicer in your area, contact: [email protected]
Posted on Jun 24, 2007
6ya staff
SOURCE:
Is the internal fan supposed to run continuously in a Hitachi freezer or does it give short interval runs? (Hitachi fridge rs700ggs8)
normally the fan on most can run all the time while the freezer is supposed to be cooling but in this might be an issue with any controls not working as it should otherwise it maybe normal
Apr 17, 2017 | Refrigerators
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
My fan runs continually, even when I switch the thermostat to 'off' between the heat and cold setting.
There would be a relay,or transistor malfunction in the unit that controls the fan motor.
Apr 16, 2012 | Heating & Cooling
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
My 60v500a fans runs continuously after shut down.
I think its a thermal sensor that is stuck open is my expert opinion the powersupply relay would have nothing to do with this. Get a service manual you will see what I am saying.
Thanks and 4 thumbs up for the hero would help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 26, 2009 | Hitachi 60V500 60" Rear Projection...
My fan runs continuously, even in the off position. Sometimes the A/C is blowing too (if it gets above the set tempature), most of the time it's just the fan. How can make it stop. This is really adding on...
is there an auto/on selector at the thermostat?
make sure its set to auto
if its set correct and still runs ...i would assume the thermostat might be the bad guy...i would open the thermostat cover and remove the "G" connection. the fan should stop running
Oct 05, 2009 | Heating & Cooling
The fan runs continuously, with thermostat set to
When was the last time you had the coils in the condenser cleaned. Dirty coils can insulate the refrigerant tubes, causing the fan to constantly run in order to try and cool down the refrigerant returning from the evaporator coils(a-coils) in supply ducting, But can.t because the condenser coils are insulated not allowing the heat to escape. I would try this first before replacing expensive parts. It is the small things that we overlook that is most likely the source
Aug 22, 2009 | Intertherm P3RA-048K Air Conditioner
Cooling fan won't turn off.
this set has more then one fan; one fan will run all the time to cool the digital circuit board---if it is the actual LAMP fan then you have a problem---the digital fan is very small and not located near the lamp.
Aug 06, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Apr 05, 2008 | GE JTP15 Electric Single Oven
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
