Question about Garmin Nuvi 660 GPS Receiver
Pairing my garmin nuvi to my blackberry
Does anyone know how to pair the garmin nuvi 200 to a blackberry curve? On the menu screen, it tells me to click tools, then settings, then bluetooth but the problem is the bluetooth option isnt there.
  • Garmin Master
  • 2,130 Answers
Nuvi 200 does not have bluetooth capability.
See this link:
https://buy.garmin.com/shop/shop.do?pID=9160#specsTab
- Jim
SHARCNET-USA
Posted on Jan 19, 2009
I have a Garmin Nuvi 680 I would like to use it as a hands off cell phone in my vechile. I no little about blue tooth. How do I go about getting my cell phone to work with my Garmin. Thanks Joe
Hi Joe,
1. First, you have to turn your bluetooth function (power) on your phone on. See your phone manual.
2. On your Nuvi, press the wrench symbol, then the bluetooth symbol. Press the option to enable bluetooth on your Nuvi. You will know that it is enabled when you see the bluetooth logo at the main menu on your Nuvi.
3. While in the bluetooth menu of your Nuvi, press the ADD button. It will tell you to turn the bluetooth function on your phone, which you should have already done in step #1.
4. Your Nuvi will start searching for your phone and if it finds it, the brand name will show up on your Nuvi's screen. Select the phone model and press OK. It will then tell you the pass key code. On your phone it will ask if you want to pair with your Nuvi. Select yes and enter the pass key code into your phone. This is usually 1234.
That's it. Your Nuvi will say you can now make phone calls. When you unit is paired to your phone and the bluetooth is turned on your phone, you will see a telephone handset at the main menu. Press that and you'll be able to select options to speak the phone number, enter it manually, transfer your phone address book to your Nuvi, etc......
If your phone isn't recognized by your Nuvi, make sure you have the latest bluetooth firmware on your Nuvi. It can be updated with Garmin's webupdater program available on their website.
- Jim
SHARCNET-USA
Feb 19, 2009 | Garmin Nuvi 660 GPS Receiver
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
I can not pair my NUVI 760 to my BLACKBERRY phone.
Works fine with my bb Curve.... as suggested get the webupdater and update ! :)
Feb 15, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Blackberry 8320 address book unable to import to Garmin Nuvi 265TW AT the start of pairing it did import it but once blacberry out of connection  from garmin or disabled, when enabled pairing address is...
The address books may not be compatible with each other regardless of pairing or not. Best bet is to check on garmin.com in the support section. If it isn't they you can use the dial up on the GPS as well as any other enhanced features that require bluetooth services.
Feb 13, 2009 | GPS
Garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Feb 11, 2009 | Garmin nuvi 265 Car GPS Receiver
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Pairing Jabra BT4051 to my blackberry
I paired my BT4051 with my BB curve just fine. I held down the power button on the Jabra until the blue light was solid and then added the device through my BB's bluetooth setup under options.
Jan 17, 2009 | Cell Phones
Lost the voice on my garmin nuvi
Go to settings, you will see blank box for language settings (where you tell it to use TTS or normal or other spoken language etc.) select language of your choice again. You will be all set. Nuvi tends to loose its voice settings sometimes.
Jan 03, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 200 Voice no longer working
Does your Nuvi 200 have a headphone jack? If so, try that with a pair of headphones. If you hear sound, then your internal speaker went bad. It's a known problem with the Nuvi.
- Jim
Sep 04, 2008 | GPS
Garmin Nuvi 660 GPS Receiver Logo
386 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
