Question about Garden
Need two cycle timing marks for a stihl st 460 cement saw
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I need a repair manual for stihl ms192t chain saw for down load
Stihl considers ALL IPLs and shop manuals proprietary.
Every time Stihl becomes aware of an on line source they force its removal.
Rules here prohibit any expert from providing you an e-mail address, if I had what you seek I cannot provide a link where you can get it.
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Posted on Feb 04, 2010
Testimonial: "I THANK YOU FOR THE EXCELENT ANSWER. I WILL TRY YOUR SUGGESTION TO SEE WHAT HAPPENS SEEMS LIKE A POOR WAY TO RUN A BUSSINES. GEORGE"
My chain wont tighten on my stihl 044 chainsaw
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Nov 20, 2013 | Stihl 440 044 460 046 Chainsaw Clutch Drum
Saw runs good but when shut off it wont start again for sometime
Check your fuel filter in case it is clogged. When starting pull cord on full choke 5 times quickly. Wait 2 or 3 seconds...try again if it asks like it wants to start..then put on 1/2 choke...goes thru same process. Check spark plug.
Sep 28, 2013 | Stihl 25" Chainsaw Saw Bar 30030008830 Ms...
Having trouble finding how to start the ms460
Hold the trigger and move the lever on the left all the way down -you know what? if you can't figure out how to start a Pro saw like a 460, you shouldn't be using it at all.
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
1998 land rover discovery oil seal same idea transmission seal?
To jlcbnyc go to www.sthilts460chopsaw.com you can get a mvery good diagram of this unit.Good Luck snor38
Jan 25, 2011 | Stihl Concrete Cutoff Saw Ts460 Oil Seal...
Your manual that came with my 18" chain saw
The main problem with running 10% alcohol fuel is that it runs hotter than non alcohol fuel.What I have done for the last 15 years in my stihl chain saws is runs fuel oil mix slightly on the rich side. Stihl reccommends mix to be 50 to 1 and I use about 45 to 1 and they run great. One saw I've been using for 10 years and have had no problems. I also use a additive called sea foam, available at most auto parts stores. I use about 4 ounces per gallon. As far as your warranty goes If you cannot get alcohol free gas I don't see where you have much choice if you want to use your saw Hope this helps. Thanks
Nov 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a part for a k 1200 mark II Need to know where nearest dealer is for zip code 45631
You can use the Dealer locator on the Stihl USA website. It will direct you to the dealer that is closest to your zipcode. I have posted the link HERE.
Oct 18, 2010 | Stihl Cutquik Saw Partner K650 K700...
I need a brake down of a stilh 460 saw
unfortunately the only place to get breakdowns for stihl is through the dealers. when i worked for the local dealer we would print them out for people so if you go down to your local dealer they shouldn't have any problems doing the for you
Feb 27, 2010 | Saws
What is the ratio of oil and gas mixture for husqvarna 460 rancher
Find an Operators and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
