Question about Refrigerators
Daewoo FRN - U20EC not producing ice
Would the fan not working cause it to stop producing?
aborcass
  • 2651 Answers
SOURCE: refrigerator failed keeping food cold, ice maker stopped working
i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
Posted on Nov 16, 2008
  • 163 Answers
SOURCE: Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Posted on Mar 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: There is icing up in drip pan causing fan to stop
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
If the coils are also icing up you have an auto defrost problem.
Posted on Jul 01, 2009
thompsonds20
  • 53 Answers
SOURCE: How to make ice cubes ?
Just fill pure water in the ice tray and allow it to cool for an hour your ice cubes will be ready. DO NOT OPEN IN THE MIDDLE TO SEE THE ICE FORMATION!
Posted on Jul 06, 2009
  • 3289 Answers
SOURCE: The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Posted on Jun 18, 2010
Hi i have installed my american fridge freezer DAEWOO FRAQ19DCB but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to t
The inlet water supply solenoid valve has two coils and valves. The icemaker valve is not functioning either electrically or mechanically. Best bet is to replace the complete assembly.
Jan 25, 2015 | Daewoo Refrigerators
Daewoo frsu201ai side by side fridge/freezer The top shelf of my freezer isn't working and the fan doesn't seem to be moving???
If the fan is defective, it will cause your problem (top not freezing but lower half ok) but could also be a defective thermostat, defrost cycle, compressor and more, which may produce other symptoms such as leaks of defrost water on floor in front or other warning lights.. First, double check that the fan it is not working by holding in the light switch, as the fan switches off each time you open the door. You may want to remove the back panels behind the ice maker, to check that the plug and wiring is ok, before purchasing a replacement If you still think it is defective, it can be replaced easily by someone with average to good DIY. It is pretty cheap to purchase a replacement on line and takes about 20 minutes to install, so Insulated well frozen food should keep ok during work.
May 20, 2014 | Refrigerators
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Have a hotpoint CSX22GRSA side by side refridgerator freezer with ice maker and ice keeps forming and stopping the fan. What could be causing this?
I don't think it is defrosting properly, possible defrost element failure, the ice being produced is smaller because of this.
Nov 20, 2013 | Hotpoint HSS25GFP Side by Side...
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
The fan on the back of our Samsung 5065w HLN television is getting very loud
This is most likely due to the tv being worked in or getting a bit old causing the parts to work harder which produces more heat causing the fan to work harder to keep the tv cool. There really isn't much you can do but by a new tv.
Oct 18, 2012 | Televison & Video
Hello, The fan on the outside condensor (38tkb042300) runs for about 45 mins and stops. Turning it off and back on will produce the same results, might you help me understand what could be causing...
There are many possible reasons why it happens that way. Basically, when the unit have reached the desired room temparature,compressor stops as will as the condenser fan.Please try to set your thermostat at its coldest setting, if the fan at the outside condenser still stops, consider replacing your thermostat, it migth be defective.
Aug 12, 2011 | Carrier 38CKC042 Air Conditioner
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
