Model 3272 thermostat does not work
Hello, I have a model # 3272 thermostat section, Max. Rating 22 amp. 125,250 vac. 18 amp. 277 vac. and it is a baseboard heater. It has quit working. I have checked everything and it is the thermostat. Where can i get a new one? Thank You
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
SOURCE: marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Posted on Nov 19, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
  • 1015 Answers
SOURCE: want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Posted on Oct 17, 2009
Adjust the temp. limit on my Model M402? Setting thermostat far below 55 degree mark, gives me 65 degrees.
Hello... may be you can set the desired temperature and later the remote control and/or the internal unit show to you the temperature of the air ... just let the air conditioning try to match your desired temperature...
Watch this...
https://www.youtube.com/watch?v=2Ck_xsdrmSM
Oct 29, 2014 | Heating & Cooling
Fahrenheat md26r
This thermostat is a DPST (Double Pole Single Throw) type meaning it will switch BOTH pairs of wires either ON or OFF. It is a type used primarily for 220 - 240 volt circuits and can switch up to 22 amps of load current. Most heaters will provide a wattage rating and some also provide a current rating as well. Since most electric heat circuits are connected to a 2 pole 15 or 20 amp circuit breaker (or fuses) via #12 copper wires it should work well. If connected to a circuit greater than 20 amps - as long as the heaters connected to the circuit do not draw more than 22 amps will also work fine.
If all is well so far, the continue. The thermostat should have 4 wires. Two of one color, two of another (black and red are common colors). One color group will be the LINE (powered) side, and the other group is the LOAD (heater) side. You should verify WHICH color group is which for best results. The switch will open and close a connection between the LINE wires and the LOAD wires.
The thermostat should be installed in an electrical switch box located on an interior wall at about 5 feet high and not above any heater or heat source. Do not locate it behind a door that swings open, etc. The box should be supplied by a circuit from the electrical panel that will connect to the LINE side color group wires *and* a circuit that will extend from the thermostat's LOAD color group wires to the heater's wire connections / terminals.
If running common #12/2 (for a 20 amp circuit breaker) or #14/2 (for a 15 amp circuit breaker) romex cable from the panel will have the Black and White wires connected to the thermostat's LINE wires and the Black and White wires in the #12/2 or #14/2 romex cable from the heater will be connected to the thermostat's LOAD wires. The ground wires will connect to each other AND a short length of the same size wire should be run from this same point to each: the ground terminal screw of the thermostat and (if using a metal electrical box) to the electrical switch box with a separately purchased green ground screw designed specifically for this purpose. Plastic boxes are not grounded.
Leave a comment if you have other questions & good luck!
Dec 09, 2013 | Fahrenheat Heating & Cooling
How can i connect a hager EH010 timer switch for DOL startor. the startor is using for 7.5 HP motor
Hello sajikumar
Following links have wiring illustrations:
http://waterheatertimer.org/How-to-program-Hagar-timer.html#wire
http://waterheatertimer.org/images/EH-010-timer-wiring2.jpg
http://waterheatertimer.org/images/EH-010-timer-wiring.jpg
http://waterheatertimer.org/How-to-install-3-phase-timer.html
The EH 010 timer has max amp rating 16 amp max.
This timer is connected to 12-14 gauge wire
Ordinary 3-phase 7.5 Hp motor draws 22 amps at 230volt and probably connected to 30-40 amp breaker and size 10-6 wire.
Timer and wire to timer must be fuse-protected, and cannot be directly connected to 30-40 amp line.
Add comment for more assistance.
Apr 18, 2013 | Hardware & Accessories
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
Oct 09, 2012 | Hardware & Accessories
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
My GE built-in oven is not heating up right away. The oven and broiler elements do not get red hot even if turned up to 500 and/or broil. As a guess it doesn't exceed 300 degrees. This is only...
It could indeed be the elements that are the problem if the elements are bad generally you will see a section of it that looks different than the rest(kinda looks like textured stucco if bad) if that isn't the case the elements must be tested to see if the proper power is going to them, you could do that by TURNING OFF POWER AT THE CIRCUIT BREAKER unscrew the element from the back wall of oven and pull element out about 6 inches out, attach a voltage meter set to measure at least 240 volts ac to the two wires, turn on breaker set oven to back and check for 240 vac to element. If 240 vac at element replace element if 240 vac not present the thermostat,or selector switch is bad not providing the 240 vac to element
Good luck,i hope this helps
Gene
Jul 31, 2011 | GE Ovens
I have a honda ex1000 generator. The owners manual gives specs of 120vac at 3600rpm. Also 12 volt dc to charge a battery. It starts and runs great but measures 240 vac at both receptacles. There is no...
if it is in fact made for the country's you stated then that's common do to they don't use 110 but unlikely do to there sales are international in reading the manual the rating is
120volt 60 Hz rated 900va max 1000va
the 12volt section 12volts 8.3 amp current
i am attaching 3 pix's of the wiring diag so you can trace the wires hope this helpsb34e74f.jpgb589d04.jpg1eb189d.jpg
Aug 28, 2010 | Electrical Supplies
Rca L32WD22 won't turn on...is there a fuse? If
Hello
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Angel
Thanks...
Aug 02, 2009 | Hyundai HLT-3272 32 in. LCD Television
Vac wont pull/**** anything while we try to vac floor,
Hello RonD30,
If you are getting suction thru the hose and not from the bottom section.. you have a clog somewhere inline with the base area... If you have access to a shop vac ... unplug the Hoover, open up the base and remove the beater bar /belt assembly.. then hold the shop vac nozzle on the point of entry to where the Hoover pulls the debris into the dirt compartment. I am fairly certain you have a clog somewhere in that ducting.. Stubborn ones may need a little motivation.. so you may be able to get an electricians snake or metal coat hanger bent to release the jam..
Hope that helps..
Regards,
Rick..
And you are right , regarding Lowes..but don't exclude Home Depot from the same rating..LOL Once the sale is done.. so are they...
Dec 13, 2008 | Hoover Vacuums
Need switch fort Presto Quartz Heater
Hello
Any hardware store should have a replacement switch for you. Let me break the numbers down to help you out.
INF = Infinite switch
120 = 120 volts
887B = model number of the switch
34-191 = date code
15 amp = ampacity rating of the switch
120 vac = Again this is a 120 volt switch A/C
If you need anymore assistence please comment back.
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
