Question about Maytag MFI2569VE Bottom Freezer French Door Refrigerator
Maytag bottom freezer leaks water - Maytag MFI2569VE Bottom Freezer French Door Refrigerator
5 Suggested Answers
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
SOURCE: Maytag side by side is leaking water from the freezer sid
We also had the exact same problem with our Maytag side by side. We kept getting a small puddle down on the floor under the freezer side of the unit. There was also a giant ice block puddle that had formed on the inside bottom of the freezer compartment. We solved the problem in about an hour. First, we pulled the unit out from the wall and checked behind and underneath the unit with a flashlight. The little drip pan that collects the water was completely dry. That told us that there was a plug somewhere in the drain line. We removed all of the food and shelves inside the freezer so we could access the inside, back panel. My husband unscrewed the two bolts and removed both panels. We found the problem. The drain pan had frozen and all of the water was overflowing inside the freezer compartment and ultimately out onto our floor. There was also a giant snowball around all of the wiring. We used a heat gun and gently de-iced the snowball and the ice in the drain pan. The manual also says you can use a hairdryer for this. Then, my husband used his air compressor and gently blew into the hole to clear out the blockage. We checked behind the unit again and saw that the clog had released and water was flowing into the drip pan. Problem solved. It is important to get the clog out of the drain line so that the problem doesn't occur again. We put everything back together and everything seems fine now. I am also going to check the defrost timer to make sure it is timing properly every 28 minutes or so. You need your manual for this to determine steps to check the timer. It is important for the timer to be set correctly so that the unit goes into defrost mode every 28 minutes. This will also help keep the water flowing and draining w/out having time to completely freeze up. The original root cause of our problem is we had a faulty ice-maker. It had overflowed about 3 months ago. The heavy surge of water, and the small plug in the line is what started this. Another problem we have had with this unit is the plastic tubing in the back. We had one of the lines turn yellow and crack. So every few months we pull the unit out from the wall, vacuum underneath and check the plastic tubing for leaks and breakage.
Posted on Nov 07, 2008
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
woodchuck789
  • 4066 Answers
SOURCE: Water is pooling in the bottom of the freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Nov 16, 2009
Testimonial: "THANKS... it's all defrosted and cleaned out and will wait to see what it does tomorrow after it's all back up and running again !! Thanks !"
How do I repair water leaking in the bottom of the freezer on Maytag model MBF2258XEW
Check your door seals. The air gets in, the moisture freezes then the defrost cycle turns it into water.
Sep 14, 2014 | Maytag Refrigerators
Maytag mff2258vew2 french door bottom freezer leaks
The cabinet heater in freezer is may not be working and causing condensation on the walls of the freezer. Have it checked by a service man.. also make sure the refrigerator is level. and it is not over packed with food. Newer models must have a certain amount of space for the air to circulate.
Oct 04, 2017 | Maytag Refrigerators
My Maytag frig model MSD2758GEW leaks water out the bottom front
I will assume that it is leaking out of the freezer side?
if that is the case the defrost drain which can be found at the bottom of the back panel inside the freezer is blocked
Jul 18, 2011 | Maytag Refrigerators
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag side be side model msd2454gr
heatman101
Jul 10, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MFI2569VE Bottom Freezer French Door Refrigerator Logo
1,604 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
