Question about Panasonic DMR-ES10 DVD Recorder
Panasonic plasma tv and self check
My panasonnic plasma tv has starting going into "self check" mode which freezes everything up including the remote and I have to shut it off at the tv. Then when I turn it back on all the presets have been lost and I have to go thru setup for all the channels, etc.
  • 11 Answers
SOURCE: Panasonic DMR E80H Video recorder remote
While pressing [ENTER] on the remote control press the [1] button on the remote - that should change the remote's control code back to one.
Posted on Aug 14, 2008
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
  • 4 Answers
SOURCE: Starts a self check then power goes off
Not sure if this will help. My machine was stuck with a "Please Wait" message. Searched internet, many folks with problem. The fixes all pointed to 2 capacitors being blown. My brother was able to easily solder 2 new ones in and the machine worked perfectly. If you Google the name and model with Please Wait after it, you will see some of the conversations and remedies. Your machine may be heading toward this problem.
Also, beware of storing too much on your hard drive! My machine was working great after the above repair, but I believe I had too much stored on mine and I got a U99 Error Code. Service Center said it can not be repaired and THEY DO NOT MAKE THESE ANYMORE. There are DV machines with a hard drive so you can watch shows, but not to record show/movies. I make DVDs of my son's high school games. Can edit and transfer many games at once with this machine... not with any others!
Do not let this one die on you. It is priceless.
Posted on Feb 19, 2009
  • 718 Answers
SOURCE: frozen screen on plasma TV
If you purchased it with a warranty, you may be able to get Panasonic to repair it. Check your warranty to get the conditions for returning it. The "new" Circuit City is operating. I do not believe they will honor purchases under the "old" Circuit City. However you can ask at www.circuitcity.com
Posted on May 31, 2009
tvservice306
  • 458 Answers
SOURCE: My Panasonic TH-42PX60U Plasma tv will not respond
need panasonic remote
Manufacturer Panasonic Part Number EUR7737Z20 Description REMOTE CONTROL
Posted on Nov 09, 2009
Panasonic plasma panasonic th-p42x10a green led on but tv takes long time for picture to appear
check for swolon capacitor in power supply or try to go in service mode and reset tv by pressing vol_ on tv and press recall button continious from remote tv will go to service mode then press vol_ on tv and ok from remote hold ok untill tv reset then unplug and turn on again.
Mar 06, 2012 | Panasonic TH Televison & Video
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
I want program my dishnetwork remote to work on my 42" viera plasma tv but i can't find the codes.
We would be happy to help you with getting your DISH Networkremote to control your Panasonic TV. We're going to start by pressing andholding the TV button located on the top of your remote until all mode buttonback lights come on, and then release. Use the number buttons to enter thecodes for your Panasonic TV; here some of the codes we currently have:512, 876, 780, 765, 689, and 819. Press the pound (#) button. To check that thecode works try several different functions on the remote to make sure it willproperly operate the TV. Remember that some codes may not be compatible withyour equipment. If this is the case, try the other codes listed for that deviceuntil you find one that is compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jul 19, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera keeps going into picture refresh mode. How can I stop this?
The tv is on "store" rather than "home" setting. If the message "going to refresh mode" keeps appearing every 5-10 minutes, do the following:
-Unplug TV from wall and leave it for about a minute.
-Plug TV back in and follow "initial setup instructions" (can be found on page 14 of manual).
You will be given the choice of "home" or "store" settings. Change it from "store" to "home".
-Done.
Aug 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Push favorite button and get "self check"
If your panasonic has intermittent power issues the tv will require service, power supply needs an adjusment that should be done by a service tech, if not then you will need a power board. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Keeps going to refresh mode
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic DMR-ES10 DVD Recorder Logo
812 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
