Question about Health & Beauty
How do I raise the seat on my Realspace Pro 510-830 Desk Chair?
I purchased my chair from Office Max "off the floor," and the store was unable to supply me with an instruction manual. I need to be able to raise the seat. Can you help me?
  • 16 Answers
SOURCE: power chair lights
The problem was a bad joystick. A local company came out to replace it and it works fine now.
Posted on Mar 07, 2009
dromtonpa
  • 40 Answers
SOURCE: JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Posted on Mar 31, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 175 Answers
SOURCE: How do I remove the chair from my Pride Mobility
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Posted on Jul 11, 2009
  • 103 Answers
SOURCE: My brother recently died and had a Jet 3 Ultra
You can email me at Christianmobilityrepairs@yahoo.com and I can give you a quote for the charger.
Posted on Jul 14, 2009
How to adjust height.
•This approach can increase the minimum and maximum heights, but only by 1/4 inch or so. 1) Get the cylinder out of the base. (This might not be easy. There are unanswered questions here how to do about this. I might have removed the wheels and then carefully stood on the star, or maybe hammered the cylinder out with a wood 4x4.) 2) Wrap a neat course or two of duct tape around the part of the cylinder that fits into the base. 3) Put the cylinder back into the base. This works because the bottom of the cylinder is tapered. (I invented and tested this fix. The seat wasn't too low, but the bottom of the cylinder was catching the carpet.)
•For a bigger raise you'd need to significantly modify the chair, which is technically demanding and risky. Modifications can fail. A chair made taller will be less stable because the base does not get wider.
•Tall adjustable chairs are sold for use at high counters. They often include foot rests, so that your feet won't dangle.
•If the desk or table wheels that can be removed, it might be easier to make the desk a few inches lower (at the expense of mobility) instead of raising the chair.
Nov 01, 2015 | Furniture
Seat sloped too far forward
You need to be sitting in the chair and the middle lever is the one which releases and secures the angle. I find the adjustment is easier if you release the backrest lever, the third lever to the rear, lean back in the chair which will raise the front seating cushion while moving the backrest back. Using you feet on the floor push back in the chair until the seat feels better. When it is at an angle you like, push the middle lever down to lock the seat in place. Then adjust the backrest with the third lever.
Apr 08, 2014 | Tempur-Pedic Furniture
Realspace calusa 857-562 office chair assembly manual instructions
This is the assembly for the Realspace Calusa Mesh Back Chair purchased from Office Depot (Item # 857-562). Mine didn't include instructions, so I chatted with customer service so you don't have to. 21937093-7787-4d5c-b10a-039106d04319.png 4653abb7-9b00-4c0c-b897-bda872bd5d08.png
Jan 19, 2014 | Furniture
What is a good height for an office chair?
office chairs range from 14.5 inches all the way up to 23inches. A good height is around 19inches. Usually chairs have a lever thatallows you to raise and lower the height as you wish.
May 29, 2012 | Furniture
Where can I buy one of those plastic things to put under my desk and chair so they don't scratch the floor?
You can buy a plastic desk mat at any stationary store like OfficeDepot and Staples. You can also probablyget one from the place you bought your desk from as they are very widelyused.
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
