Question about Sony DVP-NS305 DVD Player
Player won't play any disks only says CANNOT LOAD DISK
Any disk I try in my Sony DVP-NS305 dvd player doesn't play, its any dvd and I tryed my disk cleaner and it doesn't play that either. It is driving me mad what do i do?
  • 3 more comments
  • Simon Rubolino Jun 23, 2007
    its connected right because the sony dvd player logo comes up on the screen, its just any disk it trys to play it spins and spins and spins first and then just comes up CANNOT PLAY DISK.
  • ADRIAN M Dec 16, 2007
    No disk will play in my dvd player sony dvp ns305. All that comes up is cannot play disk. i had a look inside and disk will not spin. When i spin disk with hand its like the motor cuts in for a second as the disk accelerates for a second then slows to a stop. etching sound as laser moves back and forward along disk. Laser seems to be working as i can see red light being emitted to disk. Any ideas as to what the problem maybe. Tried cleaning laser but alas cleaning disk would not play and laser seemed hard to access with alcohol wipe. could it be spindle motor or something i can do myself. thanks for reading hoping u can help. thanks. ADRIAN M
  • bhawisha chand Jan 01, 2013
    the same thing happens with my Sony DVP-FX750 the disc spins and spins and a message comes up saying cannot play this disc. when i open it the disc still keeps on spinning.
    exactly the same thing happened to my sony DVP-FX 750. it saya loading and the disc spins and spins then a message show cannot play this disc then when i open the thing to take the disc ou the disc still keeps spinning and spinning. this happens with every disc i try.
    i live in fiji and the people here are hopeless at fixing electronics. they say they have to send it overseas and u end up paying more. i've already been through one other player by sony and the problem for that was the sound would come but no picture. if this doesn't get better i'm never buying sony again...EVER!
    Problem Solver:
  • 6 Answers
Change the way you connect the dvd player to your tv
Posted on Jun 22, 2007
2 Suggested Answers
SOURCE:
  • 231 Answers
SOURCE: player won't play any disks only says CANNOT LOAD DISK
Open unit and blow off carefully on laser eye with dust can if not there is a good chance your laser and or spindle motor in laser assembly is bad .Easy to change out .part # 8-820-237-06 (comes with spindel motor) at www.sony.com in parts/acess section ..If you do decide to change yourself make sure you unsolder small dot of solder on laser before install ..This is shipped soldered for static reasons..goodluck
Posted on Dec 05, 2007
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
I have a sony dvd player model dvp-ns305 i live in rhodes greece family send me films on formatted discs but my player says can not play this disc? can you give me advice or solution
If it plays other bought discs, then maybe your DVD player has been configured not to play pirated discs or the films weren't copied well.
Nov 25, 2010 | Sony DVP-NS305 DVD Player
My DVP-NS305 was playing all DVD's (multi-region) in colour but now only shows them in B&W. How do I change it back?
you can change colour setting in dvd setup to auto.after that colour come.when change setting power off dvd play then i will work fine.
Oct 17, 2010 | Sony DVP-NS305 DVD Player
My sony dvp-ns305 Dvd player will only play in Black and white.
first try to check the setting if its in ntsc or pal same with your television
Oct 09, 2010 | Sony DVP-NS305 DVD Player
A disk is stuck in the tray of my sony DVP-NS305 player. The disk tray will not respond to either the hand piece or the button on the player itself. The word "Locked" comes up on the display. How...
Unplug power cord, and whenb you plug power back and restart the DVD, keep pressing repeatedly the eject button on the unit.
Do this a couple of times.
If it does not work you will need to take apart the unit to take out the disk. In this case consider calling a qualified technician if you are not sure about how to do it.
Oct 04, 2008 | Televison & Video
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Some Home dvd players may not have any adjustment abilities, but you would find such things not too far away from the lense, if they don't exist, get a new unit.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
May 04, 2008 | Sony DVP-NS50P DVD Player
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Feb 03, 2008 | Sony DVP-NS305 DVD Player
you can try this
http://www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm
its for xbox but all cdrom drives are simulate
Dec 05, 2007 | Sony DVP-NS575P DVD Player
Sony DVP-NS305 DVD Player Logo
578 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
