Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
No video or sound, just blinking power light
The TV suddenly stopped working and the red power light just blinks. If I press or hold the power button, nothing happens... just keeps blinking.
I unplugged the TV for a bit, then plugged it back in and hit the power button. It starts normally and the screen lights up for just a few seconds. Then it dies, and back to blinking power light.
Any ideas?
  • 1 more comment
  • kgarriot Jan 24, 2009
    I have the exact same issue with mine. Worked fine one day then boom just stopped.
  • Anonymous Feb 03, 2009
    Turned on, no video, but sound.  TV then turned itself off and then on again.  Each time the cycle got shorter.  No audio now.  Tried unplugging with no effect.
  • Anonymous May 25, 2009
    When I turn the power button on, the red light next to the power button comes on, but there is no video or audio. TV was working fine, but one day there was a pop and the tv hasn't come on since.
    New Friend:
Did not work
Posted on Mar 31, 2012
Make sure tv not in standby mode
Posted on Jan 25, 2009
MY TV REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
Reprogram!
HOW TO PROGRAM Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Dec 30, 2014 | Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Where is the code search button
The power button is used as code search button.
To programme the URC-3021 please follow the steps
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER).
5. To lock in the code, press and release SET.The LED will
blink twice.
6. Your done with programming.
Thanx
Jul 23, 2010 | One For All URC-3021 Remote Control
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Kdf-60xs955 red continous blinking lamp light
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Philips 14inch color power problem
Take it back where you bought it.If its still under warranty, they'll work on it.If its not,they'll still advise.Hope that helps!
Jan 11, 2018 | Philips 14PT1686 14" TV
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
532 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
