Question about Mach Speed Trio Portable MP3 Player
My trioclip mp3 player wont charge
I just got this mp3 player at the beginning of this month, and it charged fully once. now everytime i try to charg it, it'll say it's charged after an hour and when i go to try to turn it on, it says it has no battery and just shuts down again. I'm really starting to get frustraded because this is the third music player I've tried(and the third brand i've tried) I really dont want an ipod since i dont want the extra stuff, but can anyone give some help?
even the number for the company would help so i can try to see what they say.
  • Anonymous Feb 19, 2009
    mi trioclip
Yeap i had the same problem that you do. Try to turn on your device and plug it in to the USB. Leave it for 5 minutes then unplug the device from the USB. It should work. ayt, peace!
Posted on Jan 18, 2009
My coby mp705 wont turn on but when i plug it to my computer it works.. what kind of assistance shall i do to make my coby back to normal? any kind of answer would be wonderful
sounds like the battery is the problem if it wont start wothout a power source
Check the system requirements for the MP3 player.
Most Coby players require Windows XP or higher and at least 1 GB of RAM to function correctly.
Check your Coby owner's manual to ensure that your machine meets all the required specifications before proceeding.
Charge the MP3 player fully.
Often, a player will act unexpectedly if it has a low charge.
A charge can also help reset the MP3 player if it has frozen or locked up.
Once the player has finished charging to 100%, see if the problem persists.
Re-sync your player.
Plug the MP3 player back in to the computer and then remove all the files.
If you have not done so already, make sure they are backed up to your hard drive.
Unplug your MP3 player and then re-load all of your files.
Check for corrupted and wrong format files.
Most Coby MP3 players only play back MP3 files, and will perform unexpected operations
if files of other formats are uploaded to the device.
Go through your uploaded files and check the extensions.
Anything that does not say ".mp3" or is not listed in your owner's manual needs to be deleted from the device.
hope this helps
Sep 30, 2012 | Coby MP-705 Digital Media Player
I bought Transcend MP860 last month. when i start charging thru PC it shows the message charging error insufficient voltage.When I finish charging it fully until it displays the message and start playing...
This is a common problem with these players (first link). My MP860 failed in this way (insufficient voltage etc message)
I made a rig with laboratory PSU (several amp output) connected to USB socket and I know that that the problem has nothing to do with voltage (voltage was stable 5V - tested also higher up to 5.5V)
For a while a trick with holding the volume up button worked for me. (see second link) But once I discharged the battery to a too low level and the trick did not work anymore.
My conclusion is that that message indicates Li-ion battery degradation and charger circuit/FW declines to charge it showing misleading message. (battery made by Foxlink)
I tore my the player open and rigged charge circuit and get it working again. Photo:
Few suggestions: 1. Never allow the battery to be fully discharged. Charge at any opportunity you have. 2. Once you get the Insufficient input voltage message try trick with holding volume adjustment. 3. If 1., 2. failed rip it open and make charging circuit or replace battery. 4. Do not buy Transcend MP3 players. (?)
Apr 11, 2011 | Transcend T.sonic 610 MP3 Player
All of a sudden it will not turn on....nothing...when plugged into the say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
How to the Zen Mozaic player is fully charged
once your mp3 player gets fully charged you can see in the screen of your mp3 player showing "full" near the battery symbol.
Dec 08, 2009 | Beond Creative Technology Zen Mozaic MP3...
How do I charge a TrioClip MP3 Player?
When charging, you have to leave it on, or it will look like it's charging but will not actually charge.
Aug 17, 2009 | Mach Speed Trio Clip MP3 Player
Mp3 wont turn on...
Press the Reset button then try charging it and if it doesn't begin to charge then take it to Radio shack.
Jul 28, 2009 | SanDisk Sansa m250 MP3 Player
How long does it charge i charged it for days but it still wont work at all so hpw long does it charge???????
Make sure that is turned on.(switch to the red side) Then once connected to USB port, it will start blinking red and green.Once fully charged the light will remain red. It takes about 2.5 hours to fully charge.
Aug 07, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
My mp3 player frooze
Have you tried resetting the player? get a thin paper clip or something similar and push the tip into the hole. then try charging it again untill fully charged, and remove from PC. Good luck
Mar 27, 2006 | Samsung YP-T8 Digital Media Player
Mach Speed Trio Portable MP3 Player Logo
220 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
