Question about Western Digital 160GB 7200RPM HDD WD1600BB 1years warranty (optonal external usb enclosure) (160G7200RPMHARDDRIVE) Drive Case
Need a case 4 a WD2000 Caviar SE Wher can I buy one ?
  • Anonymous Mar 19, 2009
    I need an external case for my WD2000 too.
Installing used WD800JD into external disk enclosure
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Nov 25, 2012 | Western Digital Caviar SE WD800JD SATA...
I looking for a pcb boad for hd western digital wd2500 caviar se
You should be able to find one here http://www.hdd-parts.com/wd-caviar-se.html
Jul 16, 2011 | Western Digital Caviar SE WD2500JB 250 GB...
My western digital wd2500jd does not get detected
try detect it from BIOS
if its not detected mean your western digital wd2500jd controller is need to be replace.
try ebay to buy its replacement.
just seacrh with keyword "western digital wd2500jd mainboard"
Mar 07, 2011 | Western Digital Caviar SE WD2500JD...
How to slave a wd800jd caviar se sata hard disk
Just install it. No jumpers are needed on a SATA drive.
Jan 01, 2011 | Western Digital Caviar SE WD800JD SATA...
I want this one WD2500JB
That is an old drive. No need to buy an exact replacement since that one is so old. Any hard drive will do. If your BIOS supports a larger drive, you can get an even higher capacity drive to replace it.
Apr 15, 2010 | Western Digital Caviar SE WD2500JB 250 GB...
My WD External Hard drive was working
Get a new case for the drive. Empty cases can be had from any store that sells computer parts.
Jul 21, 2017 | Western Digital Caviar SE WD2500JD 250 GB...
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Problem with SATA WD Caviar SE WD2500AAJS hard drive model
Maybe the sata controller on your motherboard is disabled. Try searching for the settings of your sata controller on the bios and enable it.
Jan 02, 2008 | Maxtor Hard Drive
Computers & Internet Logo
318 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
