Question about Kitchen Ranges
Maytag model mgr5710adw oven won't lite. Broiler works fine.
  • 338 Answers
SOURCE: oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Posted on Nov 27, 2008
  • 942 Answers
SOURCE: ge oven model xl44. my oven will not lite, the
Hi..
You need to do this
  • Replace the bulb
  • Test the switch
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
Good luck !!
Regards
PCmania
Posted on Jul 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore oven model#362.7122891 gas oven and broiler wont work
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
jumptrout51
  • 3361 Answers
SOURCE: Maytag Stand Alone upright Range/ Oven model
Self cleaning functions often blow fuses and relays when used.
Your relay that is blown is located behind the rear panel in the oven.
Posted on Apr 12, 2011
allbrands
  • 600 Answers
SOURCE: I have a Maytag gas
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
Oven won't come on,broiler and stove top work fine
if electric wiggle the coil then check it
Sep 24, 2012 | Maytag Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
Hi, We have a Maytag gas range. I believe it's a mgr5710adw the number is wore off and unfortunately we didn't write it down in our manual. Anyway, when using our bake burner sometimes it will...
IF the model number you have listed is what you belive to be correct thepart number for that gas safety valve is 74006427 this link i have included isa picture of it. Does it look EXACTLY like the picture if yes it will work http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/74006427/895773
GENE
Sep 23, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
