Model#6901470100 air heater serial #23403D4 090 watts 1375
Need to replace
3 Suggested Answers
  • 102 Answers
SOURCE: need upper/lower racks for Asko 1375
An authorized servicer could order them for you but I just priced them and they would cost over $300. You can find a servicer at asko's website.
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: I have a Dimplex Electric
There is a safety bi-metal strip that is probably tripping out. Does it turn back on after a cooling down period ?
Posted on Dec 05, 2010
Testimonial: "Thanks for all the advice. It is working now and has been for the last 15 minutes. Hopefully it will work for a while."
What heating element do I need for Reliant 501, Model 5 40 20LS960, Serial M97329245, element 4500 watts.
a 4500 watt element from a plumber supply shop
Take the details along but most elements are generic
Nov 28, 2015 | Element Water Heaters
Do you have plastic replacement shield for light bulb for GE Exhaust Hood - Model JV347 0XIAA - Serial GS867119C ?
I'm betting 60 watt is much higher than the wattage recommended generating way too much heat in the confined space under the plastic shield. There should be a sticker in the bulb compartment listing the maximum wattage recommended.
Nov 23, 2014 | Heating & Cooling
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Need the manual for dimplex air heater modle #6901470100
You can contact Dimplex directly, and have them email you a copy of your manual:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 14, 2013 | Dimplex Heating & Cooling
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
This will restore water heater to full 99% efficiency.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you want to test thermostats and all parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
I need to know if i have the right element for my water heater. i have the reliance 501 4500w/240v id # 5 40 2ort0 w i want to know if i need the long 1 or the bent 1. would love a pic if possible. i...
Either element will work ... straight or bent.
4500 Watt element will work, buy you can also substitute 3500, or 1500 Watt.
Stepping up wattage larger than water heater nameplate is not recommended, because wiring may not carry more watts.
Element wattage is printed on end of each element.
Reliance is AO Smith company
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
Reliance 501 manual is not available on Reliance site.
The 501 used to be standard model, but now it's the 600 series.
http://www.reliancewaterheaters.com/prod/elec.html
600 series manual is similar to your product.
page 22 shows element replacement, and says not to use greater wattage than rating plate on water heater.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Age of Reliance heater is on serial number. First character is letter. Next two characters are numbers corresponding to year. So C05222,,, serial number is made in 2005.
Nov 19, 2010 | Reliance Better Water Heater Element
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
