Question about Whirlpool Electric Range
I have a whirlpool Range, model GLP85800, Serial # 1MP4381399. Trying to access the infinity switch for top burner. Took all screw out on back panel, but the panel remains firmly in place.
jsrock516
  • 5911 Answers
SOURCE: How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Posted on Sep 19, 2008
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
SOURCE: Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Posted on May 26, 2009
SOURCE: I have a Whirlpool GS563LXSS
Hold the night light button for @ 3 seconds. It works for me.
Posted on Oct 21, 2009
jsrock516
  • 5911 Answers
SOURCE: Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 12, 2009
Testimonial: "Did not update until late, thanks for the detailed directions. No hinges on my stovetop, just detach and remove. Thanks, again!"
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Wire burning smell whirlpool range. Happens when oven or top are turned on. Smoke come out under control panel.
Had the same problem with my Whirpool range. Took off the rear panel and carefully plugged in and turned on the top oven. One of the terminals on the part labeled as 'Switch, Hi-limit' started to spark, glow and emit smoke. This part had 2 blue wires running to it. One came off of the top element in the top oven and the other fed back into the black plug on the control panel. Part in quests is held on with a single screw and has a part no. of 7403P993-60
Oct 30, 2011 | Whirlpool GR673LXSS - Stainless Steel...
Can any one help me replace the infinite switch for the warming drawer on my GE gas range JGB920bec2bb Spectra XL44. Switch part number wb24k10006. Thanks. I think I need to remove the burners and top...
Hello & Welcome to FixYa
Please view this video to follow the step by step instructions in order to replace the infinite switch in your GE Gas range:
Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kitchen Ranges
Im having an issue with my stove model # WGP 34802 the rear left burner will not turn off and the light stays on all the time
unplug range..remove the back panel to view all them wires an switches ...remove the burner knob to see 2 mounting screws ..the switch is bad or a wire is burnt at the switch check all wires an connections ... if all look good.. replace the bad burner switch..let me know good luck../joe/
Aug 28, 2010 | Whirlpool Kitchen Ranges
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have a glass cook top and one of the burners does not work how do you get at the element to replace it
Good Morning Guest,
Fist of all... Do you know for sure that you Halogen Buner needs replacing...I have found that the Infinity Switch burns out before the element does.
With the power off, remove the back panel.
Open the oven and look up where the top of oven door meets the top of oven. There maybe a screw or 2. also check the back to seeif any screws are there.
You should have a service personel help you do this because if you break it, the project will cost more.
Repace the Infinity switch first then your removal of service top
Jul 13, 2010 | Frigidaire FES367 Electric Kitchen Range
Whirlpool range
hi the part # is AP 3008287 at Appliance parts pros.com infinite switch controls the top burners thanks the appliance doc
Sep 29, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kenmore C880 6587590 burner switch replacement.
I just replaced the switch just yesterday.First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Feb 21, 2008 | Kitchen Ranges
Burners & clock are working, but oven, brioler & self-cleaner won't. Error F-0, EO
Brandyz Most likely the problem with your range is the spark module. It is located in the control panel on the right hand side. You can access it by removing the back panel held with four screws from the back. Remember to unplug the range first. The name plate with the model number and the serial number is on the frame behind the storage drawer. You can buy the spark module here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.545301030&type=10&subid= It comes with installation instructions. Gendos...post back
Jan 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool  Electric Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
