Question about Shure Beta 87A Professional Microphone
No sound I am tring to use this mic (along w/2 other Shure mic "SM58") with a powered amp. I do not get a sound when I plug-in and power up the amp. What can I do now? Can you help?
I got the same problem too with my wired 87a hooked up to my mackie dfx-6 with phantom power. no sound coming out on my single srm450v2 speaker. i'm not a tech guy and knows a little with PA's. Appreciate if anybody could share their insight.
thanks
Posted on Sep 12, 2009
  • 113 Answers
On what unit are you connecting the mics. mixer or directly to amp or powered mixer?
Posted on Aug 08, 2007
SOURCE:
Shure PGX2/SM58 Power Button
Unscrew the cartridge from the top. Slide a screw driver down inside to pop off the switch cover. Remove the large "c" clip to remove the circuit board.
Mar 27, 2012 | Shure PGX-2 Wireless Handheld Microphone...
No sound
The SM58 needs to be connected to a mic input. A guitar amp is expecting a much louder signal then what a mic can put out.
Dec 31, 2011 | Shure SM58 Professional Microphone
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Dec 13, 2011 | Shure SM58 Professional Microphone
Shure SM58 not working. Tried on various pieces of equipment using various configurations of cables and not a sound. Took unit apart and all wiring appears to be intact. The mic has been unused for several...
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
www.shure.com/service
Nov 20, 2010 | Shure SM58 Professional Microphone
I'm using Audacity with a Shure SM58 mic, and the recording plays back fine when the mic is unplugged, but if it is still plugged in when I press Play, there is no sound and the light on the mic's chord...
I assume you are using the X2u USB adapter. When plugged in, the X2u acts as your sound card for recording and playback. Thus the playback will be on the headphone jack of the X2u. You can select which sound card to use for playback in the Windows Sound Control Panel.
Aug 06, 2010 | Shure SM58 Professional Microphone
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
What is name of battery cover on shure sm58?
If you have the regular 'ol sm58 hard wired mics, there are no batteries.
Mar 01, 2010 | Shure SM58 Professional Microphone
I cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
Sep 16, 2009 | Shure SM58 Professional Microphone
Shure radio mic no sound
Call Shure Applications to help you troubleshoot at 800-516-2525, option 1. Have the wireless system and PA nearby when you call them.
Jun 04, 2009 | Shure SM58 Professional Microphone
Shure Beta 87A Professional Microphone Logo
272 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
