Kds-r60xbr2 cooling fan replacement - Televison & Video
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: sony kds-r60xbr2 televison
two things you can do
>check the color settings
>reseat the lamp
Posted on Sep 06, 2008
Cragon
  • 33 Answers
SOURCE: KDS-R60XBR2 projection 60'' Sony tv the picture is
It sems that you are having a problem with you color wheel, that is what makes the variation of color happen in your tv set, if that is not working correctly, it causes either a black and white picture, some times no picture at all or like in your case to much of one color.
Posted on Jul 23, 2010
  • 129 Answers
SOURCE: Picture color is off after circuit breaker
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Posted on Jul 26, 2010
  • 1043 Answers
SOURCE: my kds-r60xbr2 power light blinks
The power light is a part of your TV's self diagnostic system. It will blink out particular codes to help identify specific areas of concern. That particular code indicates that pin 129 of IC7002 is low (not detecting the -5 volts signal that should be present). There are a number of issues that can cause this problem, the most common being a power supply error or the thermistor that is located beside the lamp compartment. You can try and bypass the thermistor to see if that is the issue. Most of the issues that will cause this code will mean the dis-assembly of the TV, and if the thermistor is not the issue, then the power supply is probably causing the issue.
If you do not have the training, experience, and tools necessary to undertake the repairs I would strongly advise against trying to do it yourself. There are lethal voltage levels inside the TV, and one stray static shock can destroy a lot of the components inside the of it. If you do have the experience and tools, and do not have a copy of the service manual, you can download a copy of the manual at the following website:
http://www.scribd.com/doc/16940552/Service-Manual-Kdsr60xbr1
Posted on Mar 06, 2011
KDS-R60XBR2 No picture, no sound but solid green light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Power error 6 times - 11V is low. - No picture/No sound
From my past experience, yes. Not sure about the 11v being low. My kdf 45 acted that way when the main lamp went out. Found a replacement on Amazon for around $45 and now good to go! So far about a year and a half. Have had to replace about 4 for friends and family so far with same symptoms. All worked great! http://www.amazon.com/F93087600-Projection-Replacement-KDS-R50XBR1-KDS-R60XBR1/dp/B005I4OLAS/ref=sr_1_13?ie=UTF8&qid=1386773721&sr=8-13&keywords=Sony+Sony+Kds-r60xbr2+bulb&tag=donations09-20
Dec 11, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony wega KSD-R60XBR1 green screen that can not be adjusted no matter what input is used or adjustment through onscreen tv options. how do i knw if it is the color wheel, light engine, or just a bulb
It is light engine problem in your Sony KDS-R60XBR2 lcd rear projection tv.
This tv does not have any color wheel because of its light engine technology.
Lamp is just light source that provides bright white light to light engine and its working properly.
Light engine will be replaced to fix green screen problem.
If you tv model is other than above mentioned, let me know to revise this answer.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony KDS-R60XBR2 Television
KDS-R60XBR2 projection 60'' Sony tv the picture is turning yellow why is this happening
Jul 20, 2010 | Sony KDS-R60XBR2 Television
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
I have a sony tv model (KDS-R60XBR2)That is flashing 5 red on the front panel. No picture no sound,I have tried reset through remote (display-5-Volume plus)still no screen . Any ideas?Thanks Ron
I had the same problem last year and when I contacted the Sony repairman he looked it up and said it was the fan. He said the red light blinks 5 times to signal the fan is blown.(According to their booklet). He came and replaced the fan and it was as good as new. Good luck!
Jan 02, 2009 | Sony KDS-R60XBR2 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
