Turbo keeps failing on c -15 cat engine
It was building pressure in the crank case pushing oil out the dip stick and losing power. I replaced the turbo and it lasted about a week and now it's building pressure in the radiator and the shaft is loose again in the new turbo
  • Thomas F. Schneider May 11, 2010
    Your question is in the wrong place. It is listed upder computer printers. Go to the home page of this website and repost you question .
That pre-ACERT engine is a turbo eater, it cracks and consumes the turbo's turbine housing. You can solve the problem by getting the new heavy0duty turbo found at www.turbosforcaterpillars.com.
Posted on May 11, 2009
The new heavy duty turbo is no longer showing at the website posted in solution #1. It is now being shown at www.betterturbo.com.
Posted on Feb 04, 2010
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
Exaust blowing out oil dip stick
Too much crank case pressure, Cause:- blocked crank case breather, worn piston rings gases passing into engine causing excessive pressure. Remedies:- engine rebuild/ replace unit
Dec 27, 2013 | 1998 Mercury Mountaineer
2006 vw passat. screen says stop! warning low oil. engine off ? what does that mean? Also servive engine now! I just bought the car yesterday and it has no owners manual. I did notice what looked like...
First, check your engine oil level , while on level ground, add if it's low. (The oil viscosity should be labeled on the oil filler cap) Blue smoke is a sign of burning oil, not a good sign. White smoke is a sign of coolant mixing with your engine oil, a worse sign.
Your computer is telling you to check your oil, so do it, or get it done.
If your oil is low, top it off and keep checking it regularly to see if your engine is consuming it. If it is, I would recommend getting it looked at for either a leak, or low compression. (Worn out piston rings will cause oil consumption and poor performance.)
Apr 06, 2011 | Volkswagen Passat Cars & Trucks
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
Pajero valve clearance 4d56 turbo and why engine oil pop out from dip stick while enging runing?
hi the clearance on these will be 0.25 hot ( just run ) and the reason why you have oil coming out from dip stick is either you have too much oil in and need to drain some, or somewhere on the vacuum system you might have a blockage which in turn is casing a pressure build up and is forcing the oil out...hope this helps
May 31, 2010 | Mitsubishi Passenger Cars & Trucks
Engine knocking noise in 2000 saab 9-3 SE?
It's a common problem with these cars i am actually fixing mine as of now. That car is all about oil pressure and when it is low you'll start to get a tap and or what sounds like a knock due to the lifters not having enough pressure. Try taking your oil pan off and check your oil pick up line going from the oil pan to the turbo. A lot of times it gets a lot of sludge build up and makes the pressure little to none. If that looks clear check the slump inside the oil pan and see if that has sludge build up. Well hope this helped
Apr 15, 2010 | 2000 Saab 9-3 Viggen
1979 chevy 350 modded to 383 stroker i have been
Sounds like the engine can't breath,
make sure pcv valve is good,or oil cap is vented.
your engine is building up pressure and has no where to vent,so it blows the easiest thing,the dip stick
Nov 18, 2009 | 1983 Chevrolet K1500
Freelander TD4 2004 Engine light comes on at 3000rpm cuts power
I don't wish to worry you but I think the turbo kicks in at around 2500rpm and it sounds like it isn't doing so, hence the management light coming on. It could be that failing. Be careful here, apparently the turbo uses the engine oil to maintain its operating temperature and if the turbo seals fail in anyway it eats the engine oil, with the resulting total failure of the power unit. So if you do nothing else, keep an eye on the engine oil level. (You may also notice oil smoke out the exhaust as well).
Unfortunately it looks like a trip to the dealer for them to check what the engine management is saying.
Apr 01, 2009 | 2002 Land Rover Freelander
1989 sportster building pressure in oil tank
A little pressure is normal on the sportster. I have seen where if the oil tank is over full it can blow the dip stick out. Most of us who ride sportsters keep the level showing on the dip stick about midway between the low and full line. Doing this will also help with oil blow by out the air cleaner.
Mar 27, 2009 | 1993 Harley Davidson XLH Sportster 883
1,183 people viewed this question
jasbo
jasbo
