Question about Microwave Ovens
Hinari lifestyle model mx745glblk microwave not heating up
Model mx745glblk
MicrowaveSvc
  • 9098 Answers
SOURCE: hinari microwave model emx731sse will
To CEL67
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltagesection (magnetron, transformer, or diode) or the control section(door switch or control board relay or connection).
To papillion4648
Thisis usually caused by either a bad door switch, a loose door switchmount (which are pretty simple problems to fix) or occasionally aproblem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switchor mount trouble can be caused by slamming the door or by opening thedoor while it's cooking without hitting the Stop pad first.
There areplastic mounts inside the microwave which hold the door switches andonto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it'sa broken tab on the switch holder, allowing the switch to rotate justout of position. This tab can be hard to see, since it is under thebottom edge of the switch.
One test that sometimes helps is togently lift up (and/or push down) on the door or handle as you try tostart it. If it works or tries to work, then it's a door switch mount ordoor alignment issue.
If you or someone you know decide to lookinto it, we have critical information on safety, disassembly and doorswitches at our site, and our link is at our listing here on FixYa:.
Posted on Sep 27, 2008
FitzOriginal
  • 842 Answers
SOURCE: I am trying to locate instructions for a hinari lifestyle microwa
If you put "mx676tc manual" into google, you will find several companies who will supply a manual
Posted on Mar 13, 2009
6ylucy
  • 742 Answers
SOURCE: hinari microwave instruction manual
Find it here (the Elipse Microwave should fit)
Posted on Jan 04, 2010
SOURCE: Need instructions on how to
you press clock ,then clear, enter the time in 12h format! ( 24h format does not work) then press clock again :o)
Posted on Aug 29, 2010
SOURCE: Have just got second hand
I have a Hinari Lifestlye Microwave and also MANUAL!!!!!!
Let me tell you how to set the clock!
First, you press the clock button
Press the cancel button, the display will show 0
Enter the current time in 12-hour format ( this is very important as if you enter an invalid time, the display will revert to 0
Finally, press clock button again!
Posted on Jan 14, 2011
Why does my Hinari lifestyle MX780CEG make excessive noise from the magnetron area
Some magnetrons do emit a coarse buzzing sound, which is perfectly normal for them. If this is a new sound, though, it might be caused by something that has failed, or is failing, in the high voltage circuit. If the oven is not heating, the most likely culprit is the high voltage rectifier. A shorted magnetron or shorted capacitor will cause the transformer to hum much more loudly.
May 11, 2016 | Microwave Ovens
HI, WHERE CAN I DOWN LOAD A USERS MANUAL FOR MY HINARI LIFESTYLE MICROWAVE MX780CEGSL AS I HAVE LOST MY ORIGINAL ONE, THANKS
Best I can find is this one
http://safemanuals.com/user-guide-instructions-owner-manual/HINARI/MX752GMSSE-_E
Jul 22, 2011 | Microwave Ovens
Need instructions on how to set clock and select correct settings on the Hinari Lifestyle Microwave, model MX910TC??
Aug 25, 2010 | Microwave Ovens
How do I stop the beeping on a Hinari Microwave?
Unfortunately, its programmed into the software. Ive never really seen a microwave thats given the operator the option to silence the alarm.
Oct 14, 2009 | Microwave Ovens
I have a hinari lifestyle microwave 800w,it has power but no heat
no it sounds like the magnatron throw away job :( hope this helps regards jim
Apr 03, 2009 | Microwave Ovens
Mar 13, 2009 | Microwave Ovens
Problem with hinari lifestyle microwave
you will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
Mar 03, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Hinari microwave instruction manual
Jan 25, 2009 | Microwave Ovens
Hinari microwave oven
Thank you.
Visit this page and click Product Support.
A new page will pop up with their contact information.
Dec 07, 2008 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
