Question about Onkyo Tx-nr616 7.2 Thx Certified Network Receiver <<< Pre-order >>>
No signal from my projector connected to onkyo 616
Have connected samsung smart t.v into hdmi port out main which works projector into out sub but get no signal.
SOURCE: No audio sound from HDMI connection from TV to Onkyo 606 amp.
if you go to the setup menu, hardware setup, hdmi, and turn the audio out: on it should work hope this helps
Posted on Jul 29, 2009
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
SOURCE: HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Posted on Apr 30, 2010
  • 9 Answers
SOURCE: onkyo tx-sr606 hdmi problem
Yes the OSD tends to stop working. Here's how to fix it:
http://www.youtube.com/watch?v=gj0x5S9ez5U
Posted on Dec 11, 2010
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
Samsung LN-T4042H will not recognize blu ray player
The issue is with the main board circuits on your set not detecting signal on HDMI ports or selecting those ports.
How about your other inputs - do they work? Have a feeling they also will be dead. If course you can always feed the dvd rf signal to your set but the audio and video will not be up to current standards but it will work like that.
Sep 21, 2017 | Samsung LN-T4042H 40 in. LCD HDTV
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
Onkyo tx-sr875 no sound through hdmi.
Hello, I suggest having your receiver serviced. Thank you, Onkyo USA
Apr 13, 2017 | Onkyo TX-SR875 Receiver
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
I have an Onkyo TX-SR606. With an HDMI connection from any dvd player connected to the HDMI/DVD in on the Onkyo I get perfect pic and sound initially then the picture starts to go bad, usually about 5 - 10...
Hook your HDMI directly ffrom the DVD to the TV, then connect digital coaxial or optical to your receiver for audio. Your receiver will not current HDMI video codecs. That is the only fix. Sorry. Hope this helps.
Sep 25, 2009 | Denon AVR-3806 Receiver
No image/sound when sony ps3 is connected to onkyo 875
I've had problems with my Onkyo receiver too.
Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
hope this helps,
Aug 13, 2009 | Onkyo TX-SR875 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
May 05, 2008 | Onkyo TX-SR605 Receiver
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
Onkyo Tx-nr616 7.2 Thx Certified Network Receiver <<< Pre-order >>> Logo
132 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
