Question about FreeMotion Exercise & Fitness
I have a FreeMotion 730 Treadmill that changes speed on its own. The display speed does not change but the belt speed changes own its own. My best guess would be by up to 1 mph.
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
  • 13 Answers
SOURCE: Treadmill won't slow down
if you look at the front roller. there will be a black device that has two wires. this is your speed sensor. Make sure it is facing the magnet on the roller.
Posted on Aug 10, 2009
SOURCE: pro form 520 treadmill
I know this thread is a little old, but did you get your treadmill working? I have a 550e that does the same thing. The company has sent me 2 controller boards, but still doesn't work.
Posted on Jan 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: My Precor 9.21 si Treadmill shuts down upon
Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
Posted on Mar 14, 2010
  • 34 Answers
SOURCE: I have a weslo cadence 200 cs treadmill. I changed...
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
Posted on May 24, 2010
Freemotion 730 treadmill drive motor not working,
Failed motor, failed control board, could be either or both.
Jan 23, 2017 | FreeMotion Exercise & Fitness
I need to replace the motor belt but i can't remove the front roller of my H140t Healthrider treadmill
There is one screw in the front roller
  1. Loosen the rear roller
  2. Remove drive belt
  3. Remove the 1 screw in front roller
  4. Pull roller out
Jan 01, 2014 | FreeMotion HealthRider "Club" Series H140t...
Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
Dec 07, 2012 | FreeMotion 790 Interactive Treadmill
Freemotion xtr90 treadmill will start and run, but belt stops abruptly.
please LUBE the deck belt inmediately.
2) LUbe the rollers bearing too
3) test the input voltage motor , if there are the motor need repair.
4) Test the output motor board,if there are NOT voltage the board is faulty.
God bless you
Aug 26, 2012 | FreeMotion Xtr 90 Treadmill By Free Motion
How to replace treadmill running belt
First, you have to loosen the belt using the adjusting screws near the back of the belt assembly. Then you have to take the side moldings off.
Once the belt is totally exposed, you can take the belt off. Reverse the procedure to tighten the belt and align it
Aug 07, 2012 | FreeMotion treadmill t7.5
My freemotion treadmill is slipping, what can I do?
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Oct 24, 2010 | FreeMotion Treadmill t7.3
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Exercise & Fitness Logo
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
