Question about Epson Stylus C84 InkJet Printer
C84 not printing - Epson Stylus C84 InkJet Printer
  • Fremont4 Jan 26, 2009
    I have an Epson Color Stylus C84 and replaced the magenta and cyan cartridges recently with Epson brand ones. The printer is no longer printing in color. Not sure why. I use the printer practically everyday.
  • Fremont4 Feb 13, 2009
    Thanks for the suggestion. I ran three more head cleanings then a print nozzle check. Still no color ink. It was working fine and one day no color ink would print. The cyan and magenta are 2/3 full and the yellow is about 1/4 full.
  • 353 Answers
I assume that before the old cartridges ran out of ink, everything was printing normally. If so, the usual reason for this problem after a cartridge change is getting air into the print head system. Did you do a proper cartridge replace process, which finished with an ink charging cycle? Have you tried running 2 or three head cleaning cycles? If not do it, then run a nozzle check. Any sign of ink - yes - then things are OK you've just got to get the ink flowing properly. Run a couple more cleaning cycles then leave it to rest for 24 hours to let the air bubbles disperse. Then try again.
If you get no sign of ink after these processes report back.
Posted on Feb 01, 2009
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
Printer keeps printing lines across the page of 1
Width of head sprayer (head output) of black is about 1". Check nozzle. It might be some point of head spayer distort. See check nozzle ouput. There are tranversal and vertical lines that represent same point of head sprayer. Is the output perfectly straight and no clog at all? Do head cleaning procedure.
Aug 21, 2009 | Epson Stylus C84 InkJet Printer
Not printing
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Feb 21, 2009 | Epson Stylus C84 InkJet Printer
Stylus is not printing
It appears that gbmalabanan and guest have lost interest in this problem, so I think we may post it as "Solved by Posters".
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Epson C84
go to printers, right click on the printer icon, choose printing preferences, then click on maintenance. you will find everything you need there.
Jul 01, 2008 | Epson Stylus C84 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
Can you print something with a different program such a Microsoft Word? If you can then the problem is with LWORKS if not then the problem is with the printer driver. Please respond so I can help more.
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
Printer not printing
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
